Grid report
#1 Posted : Saturday, July 1, 2023 12:48:09 PM(UTC)
Dennis, currently this report only shows QSL = F if you have paper. If you have only LOTW confirmend, it will still show worked = W, not worked = F
Is there a way to make it show worked = F if either LOTW or Paper = F
#2 Posted : Saturday, July 1, 2023 7:30:13 PM(UTC)
Hi Doug, hope you are well !!
Mine shows correctly when selecting either "prefer paper" or "prefer Lotw". The attached pic shows a partial GRID Awards report (paper preferred) where even though there is no hard QSL the field QSL-R is F if Lotw-R is F. Not sure why you would be seeing "worked" if Lotw-R was F.
Grid Rpt-Paper_Lotw.png (120kb) downloaded 106 time(s).
WN4AZY on 7/2/2023(UTC)
#3 Posted : Sunday, July 2, 2023 10:03:50 PM(UTC)
Hi Brad, Here's what mine looks like. For example, see 5W0M.....I don't care if it's paper or LOTW....I just want to know if it's confirmed or not at this point. If for some reason I need to dig deeper, I will.
grid report.PNG (30kb) downloaded 111 time(s).
#4 Posted : Sunday, July 2, 2023 11:01:13 PM(UTC)
So I assume then 5WOM was confirmed via LoTW and if you run the same report with LoTW as preferred it then shows as F ?
Just to be sure nothing was funky in the legacy report I ran it and got the expected results for paper or lotw preferences. Shouldn't make any difference which is preferred, if confirmed they should show as QSL = F. Maybe Dennis can provide a link for the AWARDS report files and you can replace yours with those.
WN4AZY on 7/10/2023(UTC)
#5 Posted : Tuesday, July 4, 2023 2:34:04 PM(UTC)
Exactly. Thanks, Brad!
#6 Posted : Wednesday, July 5, 2023 6:52:38 PM(UTC)
Ok, I was stumped why the Awards [Grid] report is doing this except I noticed all the QSO's in your pic reported as "W" EXCEPT the ones that had paper....so, I'm thinking 5W0M isnt the only LoTW confirmed QSO in that list right ? If so, navigate to Tools/Setup/Log Fields, select the Grid Log Field, then the Awards Tracking & Spotting tab (see attached) and insure "Is a QSL from Logbook of the World OK for this award" is checked.
If thats not it let us know...
Grid Rpt-Paper_Lotw-LogFieldSetUp.png (71kb) downloaded 107 time(s).
#7 Posted : Wednesday, July 5, 2023 7:54:31 PM(UTC)
Yup, that fixed it! Many thanks, Brad!
#8 Posted : Wednesday, July 5, 2023 9:44:31 PM(UTC)
Glad that worked !!!
It was bugging me....hihi
Best 73's, Brad
