Adding County to Mini Log Form
YS1GR
#1 Posted : Friday, May 25, 2012 12:23:42 PM(UTC)
Hi Dennis, I have Logic 9 working pretty good. I need for you to walk me thru straightning out a couple of problems. I use the mini log form for my general logging. When it enters the address of the station there is no user field for the County so this info isn't filled in on the main log form. Can you walk me thru the procedure on how to set up the County as a field in the mini log . Also what is a easy way to update or add conties to the County drop down menu?
73 de Gary YS1GR
#2 Posted : Wednesday, May 30, 2012 8:23:01 PM(UTC)
Ok, this is covered in the manual and help.
Please refer to sect 5.2 of the manual. If you need to add more user-defined fields to the log form, go to the Additional Fields page referenced in this section (actual page# varies depending on manual edition).
And another similar discussion here:
http://hosenose.com/Foru...t-Mode-to-Log-Form.aspx
Then let me know if any clarifications are needed.
The county list and all awards lists in LOGic are in tools/setup/lists of valid values. Let me know if questions on this also. It works exactly like the log form with respect to adding, updating, and removing records.
YS1GR
#3 Posted : Friday, June 1, 2012 3:18:00 AM(UTC)
Thanks Dennis, what thru me off was that the hide field was checked in the drop down menu and I could not find the display. Once I unchecked I could find it.
Gary YS1GR
