problem installing 10.0.16
#1 Posted : Monday, May 8, 2023 8:19:23 PM(UTC)
I thought you were using a code signing certificate now for LOGic. Just downloaded and tried to install 10.0.16 (coming from 10.0.14). Norton intercepted it and would not let it install. I thought you resolved this issue? There's a workaround that takes me 1-2 hours of uninstalled Norton, disabling Windows Defender, whitelist and install the update. Then re-install Norton and put the exceptions for private compiled code back as fast as I can before Norton deletes them.
Thanks & 73s,
Don
EDIT: If it helps, LOGic 10.0.11 was the first one that installed smoothly.
#2 Posted : Wednesday, May 10, 2023 2:35:05 PM(UTC)
Yes, it has been resolved, EXCEPT that I put up an update to 10.0.16 to include a new webdriver file. I am traveling and do not have the signing dongle with me.
Everything INSIDE the install package is still signed, including LOGic.exe. The installer itself is not signed.
Windows Defender shouldn't complain. The unsigned one installs here fine. Norton, who's to say? Normally the only thing that complains is the web browser, and that is easy to get around.
I apologize.
