Problems with downloading from EQSL
TF5B
#1 Posted : Saturday, May 6, 2023 9:40:40 AM(UTC)
Billi
I just updated from Logic 10.0.9 to 10.0.16 and get this error message when I try to download from EQSL.
OLE |Dispatch exception code 0 from WebDriver: binary is not a Firefox executable..
I did have LOGIc 10.0.9 installed and there this was ok.
How can this be fixed?
Any help would be good.
73 Billi TF5B
#2 Posted : Sunday, May 7, 2023 9:20:33 AM(UTC)
Hi Billi--
Sorry for the problem.
It looks like the problem is actually with the Firefox interface, and not eQSL. Please verify this by clicking the CIA button on the Info form. Make sure the info form is not blank before doing this. If you get the same error, it is firefox.
It works here. Please try getting the lastest Firefox. Click Help then About Firefox.
Tnx for using LOGic.
TF5B
#3 Posted : Sunday, May 7, 2023 9:49:24 AM(UTC)
Billi
Hello Dennis and thank you for the replay.
If I click the CIA button I do get the same error message.
I am using the latest version of Firefox or at least that is wat Firefox is telliing me.
This has never been a problem befor and if I do go back to LOGIc version 10.0.9 all is ok.
What can I do to fix this?
73 Billi TF5B
TF5B
#4 Posted : Tuesday, May 9, 2023 11:15:09 AM(UTC)
Billi
Any help Dennis???
73 Billi TF5B
#5 Posted : Tuesday, May 9, 2023 12:32:15 PM(UTC)
Billi,
You need the matching web driver for the browser/version you're using.
Firefox driver needs the gecko driver here: https://github.com/mozilla/geckodriver/releases
Chrome needs: https://chromedriver.chromium.org/downloads
Microsoft Edge needs: https://developer.micros...t-edge/tools/webdriver/
Unpack the file to the assembly subfolder as approprite. In my case, "C:\Program Files (x86)\LOGic\assembly".
73s,
Don, W2ZI
WN4AZY on 5/10/2023(UTC)
#6 Posted : Wednesday, May 10, 2023 2:24:52 PM(UTC)
Sorry for the delay in getting back. I am out of town.
I have FireFox version 113. It works with LOGic 10.0.16 no problem.
What version of Firefox do you have?
The problem with FireFox is that the version number of the driver is different than the version number of Firefox. That is also good. If you don't have exactly the same driver version as the Chrome or Edge driver, it won't work. However, the same version of the Firefox driver will work with several versions of Firefox. It seems so long as you have the latest version, all is good.
Here is the latest driver. Unzip and put in c:\program files (x86)\assembly
https://github.com/mozil...river-v0.33.0-win32.zip
That, with Firefox 113, works here.
What is confusing is the error "binary is not a Firefox executable." That doesn't look like a version mismatch, if such a thing even exists in Firefox. Is your computer 64-bit? Just curious. Shouldn't matter.
A workaround is to set your system's default browser to Edge or Chrome.
TF5B
#7 Posted : Thursday, May 11, 2023 3:08:37 AM(UTC)
Billi
Hello Dennis and thank you for nthe replay.
My Firefox version is 113.0 64 bit and the webdriver is the same as you ar using but it does not work.
Well I am not going to spend more time on this because I do not use EQSL for my selve but just upload my qso's as a service to others that have qso's vith me and are using EQSL.
I also did find another workaround and that is to download from my EQSL inbox to a file that I can import to LOGic every now and then.
So thank you for your help.
73 Billi TF5B
1 user thanked TF5B for this useful post.
WN4AZY on 5/15/2023(UTC)
#8 Posted : Monday, May 15, 2023 7:18:23 AM(UTC)
Another idea -- try disabling any virus checkers etc.
#9 Posted : Thursday, May 18, 2023 2:25:25 AM(UTC)
Having trouble here also with eQSL...I get the attached error message.
TF5B
#11 Posted : Sunday, May 21, 2023 11:02:41 AM(UTC)
Billi
Hello Dennis.
I did try that but it did not change anything.
The problem is still there.
73 Billi TF5B
#10 Posted : Sunday, May 21, 2023 10:14:35 PM(UTC)
Please install the 10.0.16 again. It includes ChromeDriver 113.
OZ4CG
#12 Posted : Tuesday, August 1, 2023 7:43:43 AM(UTC)
Carsten Gjessing
Hello Dennis
After installing Ver. 10.0.17, I cannot download e-QSL.
I get the enclosed INFO, and can se in the folder LOGIC/Assemply-folder, that Cromedriver115 is missing.
Can I download it somewhere to fix the problem, or have you to make a new version to include it?
Hope top hear from you.
Best 73 Carsten / OZ4CG
Skærmbillede 2023-08-01 14.29.02.png (9kb) downloaded 143 time(s).
Skærmbillede 2023-08-01 14.32.29.png (125kb) downloaded 143 time(s).
#13 Posted : Tuesday, August 1, 2023 10:41:56 AM(UTC)
Please download .17 again and reinstall. I updated it sometime last week. I just deleted ChromeDriver115.exe, and installed .17, and it reappeared, so I know it is there.
Please note that if I merely update Chromedriver, I will not create a new update version. So in most cases, downloading and installing again will fix it. If not, let me know and I will add it to the latest update.
http://hosenose.com/Foru...r-errors.aspx#post11090
I bolded the relevant part hihi.
OZ4CG on 8/4/2023(UTC)
OZ4CG
#14 Posted : Friday, August 4, 2023 7:15:20 AM(UTC)
Carsten Gjessing
Hello Dennis
Thank you for your quick reply!
I went to the download site and noticed a new version (#18), and after download all is OK.
Thankyou again, Dennis!
All the best 73
Carsten / OZ4CG
1 user thanked OZ4CG for this useful post.
WN4AZY on 8/6/2023(UTC)
K6JJ
#15 Posted : Monday, September 11, 2023 4:18:18 AM(UTC)
Hi Denis and Billi,
I am also having the same problem of downloading from EQSL. Uploading to EQSL is not a problem.
The error message I get is: "OLE IDispatch exception code 0 from WebDriver is not a Firefox executable."
I have downloaded the latest Gecko drivers, both 32 and 64 bit versions. My computer is a 64 bit Windows 10 machine.
I have tried copying both version, one at a time, to: C:\\Program Files (x86)\LOGic\assembly. They did not fix the problem.
Denis, as you mentioned, I switched over to the Chrome browser, where I could download from EQSL. However, I have used the Firefox browser for a very long time. Using Firefox, I used to have the ability to download from EQSL.
I have waited to describe this problem, hoping that a newer version would fix it, no luck. I recently found and read this forum thread.
John
TF5B
#16 Posted : Monday, September 11, 2023 9:05:01 AM(UTC)
Billi
Hello John.
Well I still have this problem and I am using the newest update to Logic.
I hawe tried all you say you have tried, with out luck exept, crome and I am not going to trie that.
So the problem is till there.
73 Billi TF5B
#17 Posted : Monday, September 11, 2023 4:28:31 PM(UTC)
Hi Guys:
Does the CIA button on the Info form work with Firefox? I tried it here with the Firefox driver that came with LOGic 10.0.20, and it works. My Firefox is 117.
Download EQSL also worked. I don't think Upload EQSL uses a browser, so it wouldn't fail in this case.
I got the gecko driver here:
https://github.com/mozilla/geckodriver/releases/
Get
geckodriver-v0.33.0-win64.zip
Assuming you have the 64-bit version of Firefox.
Just a thought: Be sure to unzip the .zip file and get geckodriver.exe out of it. If someone just renamed the .ZIP file, that would explain the error.
K6JJ
#18 Posted : Monday, September 11, 2023 9:13:56 PM(UTC)
I downloaded and installed the 64 bit gecko driver from the link you supplied. I use the 64 bit version of Firefox. There were different version dates between the version I was using and the version from your link. I used the correct driver name. The new driver did not fix the problem.
I clicked the CIA button within the Info form. It did not work. I got the same type of error messages.
John
K6JJ
#19 Posted : Monday, September 11, 2023 9:20:49 PM(UTC)
I have attached screen shots of the error messages I got while trying to download from EQSL. They are in the order I received them, as I clicked on Yes To Continue for each error message. After message #5, Logic returned to operation; it did not crash.
John
K6JJ
#20 Posted : Monday, September 11, 2023 9:24:33 PM(UTC)
I have attached a screen shot of the first error message I got while trying to download from EQSL.
John
Error Message.PNG (9kb) downloaded 111 time(s).
Error Message.PNG (9kb) downloaded 127 time(s).
Guest (10)
This page was generated in 0.091 seconds.
