DISPLAY PRINT DIALOG check box
N6DHZ
#1 Posted : Wednesday, May 3, 2023 3:44:41 PM(UTC)
jshryne
Starting in ver 10.0.14 and subsequent updates.
When printing DYMO QSL LABEL and you un-select DISPLAY PRINT DIALOG check box and print your label(s) it used to remember your selection the next time you print that label. Now it re-selects the
DISPLAY PRINT DIALOG check box. Not a big issue when printing batches of labels but I print a lot of single labels and it's a pain to have to un-select the box every time. This does not happen
with for example QSL LABLELS 3-ACROSS.
Also with version 10.0.15 I sometimes get a window pop up asking me to select a .dbf file. If I click cancel enough times it will go ahead and print the label with no issue. This will happen with
both DYMO QSL LABEL and QSL LABLELS 3-ACROSS.
LOGic Ver 10.0.16
WIN 10 PRO
VER 22H2
OS Build 19045.2846
FEP 120.2212.4190.0
WN4AZY on 5/10/2023(UTC)
#2 Posted : Wednesday, May 10, 2023 4:25:03 PM(UTC)
Thanks for the report. I'll check it out.
N6DHZ
#3 Posted : Wednesday, May 10, 2023 8:37:42 PM(UTC)
jshryne
Also just noticed if you display it to the screen and then print if does not ask you if you want to mark the QSL as printed.
WN4AZY on 5/15/2023(UTC)
#4 Posted : Monday, May 15, 2023 7:20:08 AM(UTC)
Thanks -- you did the detective work for me! I'll see if this is fixable.
