New Report Previewer two-sided printing not working
#1 Posted : Sunday, January 29, 2023 11:37:19 AM(UTC)
Was thanked: 229 time(s) in 206 post(s)
When running the new report previewer and you print from the previewer's toolbar, the two-sided parameter "Print on both sides (manual)" prints one-sided regardless of the checkbox being checked, nor does it remember the setting. Maybe that's just how it works but it would be nice to print two-sided and have it remember the setting from the previewer window. All works fine from LOGics print window.
#2 Posted : Wednesday, March 29, 2023 5:46:45 PM(UTC)
Just a re-kindle of this issue.
#3 Posted : Friday, March 31, 2023 1:36:16 PM(UTC)
Thanks for the bump.
I tried it here, and had the same problem. There are some updates to the previewer, so I will install that in the next update.
However, I suspect that it will never work. I have never seen any other application that has its own double-sided printing built-in like that. Note that it says "Print on Both Sides (manual)." Not sure what to make of that.
The solution for double-sided printer is simple. If you want to print paper, don't use the Print to Screen option in LOGic. Checkmark the DISPLAY PRINT DIALOG option, and print as usual. When the print dialog appears, your the dialog from your printer's manufacturer appears. Choose 2-sided printing from here.
#4 Posted : Friday, March 31, 2023 9:47:20 PM(UTC)
I do that, just was hoping that the feature in the previewer would work. Not sure what "manual" implies either but probably moot if it doesn't work anyways.
WN4AZY on 4/5/2023(UTC)
