Duplicate QSO's
w7gtf
#1 Posted : Monday, March 13, 2023 7:19:39 PM(UTC)
I recently noticed, when bringing in an ADIF log from a second transceiver, not connected to Logic, only the WSjt-X log, that I had a number of duplicate QSO's Almost always on FT8. I ran the dupes program and that got rid of some. Looking through my log again, I still see a lot of dupes, primarily FT8 where QSO's are off by a few seconds. Any way to get rid of these remaining dupes? Or alternatively, anyway to search for the dupes and get rid of them by deleting the entries - a tedious task.
I also wonder if the dupe program would delete dupes without regard to the time if they're same mode, date. Ones I see are off by over a minute, so not paying attention to seconds does not help.
Ron/W7GTF
#2 Posted : Wednesday, March 15, 2023 10:12:12 AM(UTC)
Was thanked: 544 time(s) in 454 post(s)
No problem.
Look in C:\Program Files (x86)\LOGic\util for "delete duplicate qsos.prg"
Edit it with notepad or whatever.
Look for this line:
select * from tmp\dupelog.bak group by call, qso_date, DupeTime, DupeTimeOf, operator into CURSOR dupetemp
Comment it out by putting an asterisk at the start of the line, then put a new replacement line below as shown:
* select * from tmp\dupelog.bak group by call, qso_date, DupeTime, DupeTimeOf, operator into CURSOR dupetemp
select * from tmp\dupelog.bak group by call, qso_date, operator into CURSOR dupetemp
I will attach a copy of the modified file, but probably just as easy to modify the existing one. And just to let everyone know that the misc utilities are user-customizable hihi.
delete duplicate qsos.prg (3kb) downloaded 130 time(s).
w7gtf on 3/15/2023(UTC)
#3 Posted : Wednesday, March 15, 2023 4:22:36 PM(UTC)
Oops, I screwed up. The above does not consider mode as you requested. Try this. Sorry if I messed you up.
delete duplicate qsos.prg (3kb) downloaded 118 time(s).
w7gtf
#4 Posted : Wednesday, March 15, 2023 7:47:27 PM(UTC)
Huh,
I read your program over several times and thought something was missing. Thank you - I’ll give this a go,
Ron
1 user thanked w7gtf for this useful post.
WN4AZY on 3/16/2023(UTC)
w7gtf
#5 Posted : Friday, March 17, 2023 7:14:53 PM(UTC)
Looks like the second program did the job. Took out 3600 dupes. Now how do I get that second .prg back into the Logic program in the Misc Utilities?
I'm not much of a programmer :)
Thanks again,
Ron
#6 Posted : Monday, March 20, 2023 4:49:34 PM(UTC)
Was thanked: 153 time(s) in 136 post(s)
Navigate to c:\program files\x86\logic\util and drop it there, it will replace the existing one.
WN4AZY on 3/21/2023(UTC)
w7gtf
#7 Posted : Monday, March 27, 2023 6:22:55 PM(UTC)
Doug,
Thank you for the idea. However, I can't seem to get it into util - if I drag and drop, I'm told I don't have access. Any other thoughts on getting it into the utilities?
Ron/W7GTF
#8 Posted : Tuesday, March 28, 2023 10:47:14 AM(UTC)
Log into your computer as administrator.
WN4AZY on 3/28/2023(UTC)
w7gtf
#9 Posted : Tuesday, March 28, 2023 7:30:07 PM(UTC)
Thanks, Doug
That got it done. I should have remembered that myself.
73's
Ron/W7GTF
