v10.0.9 screen pop-ups dont sync with multiple monitors
#1 Posted : Tuesday, November 1, 2022 4:18:55 PM(UTC)
Installed 10.0.9 but now all the sub pop-up windows appear on a different monitor then LOGic's desktop. I have LOGic on Monitor 3, if I click on the binoculars in the Log window the pop-up now appears on monitor 1. Same thing occurs for every other sub pop-up window, like log set-up windows, reports, awards, etc.. Moving them to LOGics desktop monitor doesn't do anything, the next time they just appear back on monitor 1 instead of the same monitor LOGic is on.
Going to revert back to 10.0.8 for now.
Thanks, Brad K8ZM
Added attached pic.
WN4AZY on 11/6/2022(UTC)
#2 Posted : Sunday, November 6, 2022 1:16:55 PM(UTC)
I am seeing that too.
#3 Posted : Saturday, January 21, 2023 7:38:17 AM(UTC)
Any update to this? I'm using 10.0.12 and the issue is still in this version.
#4 Posted : Sunday, January 22, 2023 9:49:29 PM(UTC)
Sorry, I didn't get to it until now.
Please try the new 10.0.13 update, and let me know.
I fixed a few other windows that do the same thing. There are a few more to go.
K8ZM on 1/23/2023(UTC)
#5 Posted : Monday, January 23, 2023 2:16:40 PM(UTC)
Installed .13 and it seems, of the pop-ups it appears "changed", they now appear at the top left of the same display (instead of fixed in the center) and can be moved but will revert back to the top left of the same display when re-opened. There's a ton of sub-menu windows, I'll have to make a list of which do what when.......who's on 1st ??? hihi !!
Timne for a beer...I'll buy !!
#6 Posted : Monday, January 23, 2023 8:06:08 PM(UTC)
Does clicking the Binoclar button (Get form) work? I fixed all of those. At least they look good here.
Here is how they work: If the log window is in the main LOGic window, the Get window will open in the center of the main LOGic window. If the log form is located free of the LOGic window on the Windows desktop, it will center itself on top of the log form.
Right, you can move them, but they do not remember the position. By design they and most other popup windows are supposed to open in the default position which should be near center of what you are working on.
Don't knock yourself out. After I confirm that I have or haven't fixed the Get windows, I will go thru the others.
#7 Posted : Monday, January 23, 2023 9:12:41 PM(UTC)
Ok, so YES, binocular in either the Logform or the Browser brings the window right up in LOGics desktop.....Beautiful !!
I'll go "knock" on wood !! BigGrin
#8 Posted : Tuesday, January 24, 2023 3:01:07 PM(UTC)
The binoculars work for me but I still get windows opening in other monitors, specifically the IMPORT and EXPORT QSL windows.
#9 Posted : Tuesday, January 31, 2023 11:36:37 AM(UTC)
Do you have a timeline when the 'window jumping' issue will be tackled?
Thank you
#10 Posted : Tuesday, February 28, 2023 8:24:29 PM(UTC)
Bumping this up. Any timeline when the window hoping issue will be fixed?
#11 Posted : Thursday, March 2, 2023 5:15:07 PM(UTC)
Thanks for the reminder. I'll work on it this weekend or next week Lord willing.
#12 Posted : Thursday, March 23, 2023 7:23:14 PM(UTC)
Bump BigGrin
WN4AZY on 3/28/2023(UTC)
#13 Posted : Friday, March 24, 2023 11:11:36 AM(UTC)
Same here, Dennis. When you do reports, you're all over the place. If you have lots going on, it can be quite confusing.
#14 Posted : Wednesday, April 5, 2023 10:50:37 AM(UTC)
Bump BigGrin
#15 Posted : Monday, April 17, 2023 12:24:10 PM(UTC)
I installed the latest update but didn't see in the description this was addressed.
Bump BigGrin
#16 Posted : Tuesday, April 18, 2023 8:23:11 PM(UTC)
Sorry, no change was made to this in the .15 update. I will get to it as soon as able. I appreciate your continued patience.
#17 Posted : Thursday, April 27, 2023 10:34:26 AM(UTC)
Ok, try the 10.0.16 update. If you see anything amiss or any windows I missed, please post here.
Sorry for the delay on this. It required a fairly major effort.
#18 Posted : Friday, April 28, 2023 12:30:54 AM(UTC)
Thanks Dennis !!
Found a couple "rogue" pop-ups;
In the Logform Setup window, hitting any expression builder icon (funnel) in any tab pops-up the expression builder window on another monitor.
In the Miscellaneous Setup window if you hit the Com Port Usage Icon (the D-Shell Icon) the Usage window pops up on another monitor.
I'll post any more I run across. There are a ton of them for sure !!
Best 73's, Brad K8ZM
20230501 - a couple more not popping up on same monitor as LOGic: Tools/Export Log Data window, also the "Find" window when you edit that exported file (find and replace) and the subsequent "Ok" window to save the file.
#19 Posted : Thursday, May 4, 2023 2:07:41 PM(UTC)
Just installed latest update, here's what i"ve seen so far:
- Export and Upload QSOs to LoTW, the QSO Date Range window opens in another monitor
- Backup/restore, the compress/uncompress window opens in another monitor
- Help > About, the About LOGic window opens in another monitor (not a big issue)
WN4AZY on 5/10/2023(UTC)
#20 Posted : Wednesday, August 2, 2023 9:44:26 AM(UTC)
I did some more work on this. The changes are in the new 10.0.18 update.
These now default is to position to the center of the monitor that contains most of the main LOGic window. However, it remembers the last position, so you may not see any change. Move it to the monitor you want it on, and it should stay there.
Fixed
Fixed
Also, you should be able to rearrange or remove monitors, and windows whose title bar off-screen and not visible in any monitor should now move to the closest monitor and display enough of the title bar so you can grab it and move the window.
If the main LOGic window's title bar is found to be inaccessible, the main window will be centered and sized to the main monitor.
Tnx for your patience on this.
If anyone sees any other problems, please reply here.
K8ZM on 8/2/2023(UTC)
Guest (11)
This page was generated in 0.098 seconds.
