5 Band DXCC report
KV3R
#1 Posted : Sunday, November 27, 2022 8:44:42 PM(UTC)
Was thanked: 2 time(s) in 1 post(s)
I would like to run a 5 Band DXCC report with what cards to use. I want to run it from 11-96 to now. My log starts in 1993. I have had 2 call signs in between 11-96 to now. My log also has my LoTW confirmations in it. I have tried and failed.
Thank you for your help.
73, Bill KV3R
#2 Posted : Sunday, November 27, 2022 9:16:09 PM(UTC)
You are looking for cards to submit for DXCC? Unfortunately you will have to do it one band at a time using the AWARDS report.
Click NEXT to fill out the various options. You have the option to give preference to a paper card or LOTW if you have both. The last option is INITIAL SELECT CRITERIA. Use this to set the starting date.
Tnx for using LOGic.
PS Also check out the CARDS NEEDED FOR AWARD report. Suppose you have a given country worked but unconfirmed. It will show all QSOs with that country to help you decide who to follow up with.
KV3R
#3 Posted : Monday, November 28, 2022 12:27:24 PM(UTC)
Still having trouble. I can not seem to get the start date to work. Also when I print to screen for 80m DXCC all I get is Country Prefix. I do not want to mark QSO's in the log. I have numerous file card boxes filled with cards that I pulled years ago when using Logic 4. The bad thing is I didn't mark the boxes as to what award they were for (5 band DXCC, 5 Band WAS and 5 band WAZ. I'm hoping Logic will still pick the same cards I have pulled. I would like to see the complete call sign. Is it possible for you to walk me through step by step?
Thanks for your help.
73, Bill KV3R
#4 Posted : Monday, October 23, 2023 8:58:49 AM(UTC)
Was thanked: 160 time(s) in 142 post(s)
Bill, here's how I do it:
Go to Reports > Awards > Awards > DXCC
select the band > next
print unworked entities yes/no as desired > next
tag marking submitted cards leave blank > next
select field to print in optional column - do nothing > next
initial select criteria, this is where you will do your date...click the expression builder button on the right side
scroll down in the expression builder screen until you find the field "QSO Date". Now go to the operator drop down and select "greater than or equal", and where it says "value" enter your start date. Click "OK"
click finish
leave "award value" > ok
leave "QSL_RCVD $ "SFRWU""
select print.
WN4AZY on 10/23/2023(UTC)
