Apparent WSJT-X logging issue with 10.0.10
WD4ASP
#1 Posted : Saturday, November 26, 2022 10:08:39 PM(UTC)
After updating to 10.0.10 I encountered an issue when trying to log WSJT contact:
Error 1426 "OLE error code 0x80004002: No such interface supported." has occurred in program IMPORTADIFRECORD.IMPORT, line 82. Attempt to continue.
So I clicked yes and got the following error message:
Error 12 "Variable 'FLDINFO' is not found." has occurred in program. IMPORTADIFRECORD.IMPORT, line 84. Attempt to continue?
Then I clicked No and got the following error message:
Variable 'CALL' is not found.
Most likely the last two errors were due to the initial failure. Let me know if you need any other information.
Fred
#2 Posted : Saturday, November 26, 2022 11:54:33 PM(UTC)
Sorry for the problem.
Please re-download and reinstall the 10.0.10 update.
I fixed this sometime Thanksgiving day or maybe yesterday. If you downloaded it just before you wrote your message, that is a different matter. Let me know. However, I just reinstalled from the updater and it is fine.
WD4ASP
#3 Posted : Sunday, November 27, 2022 11:11:19 AM(UTC)
I had downloaded 10.0.01 on Nov 24. Just downloaded 10.0.10 again and that solved the problem.
Fred
