Groups: Administrators, Beta Testers Posts: 3,266  Location: Auburn, GA Thanks: 1145 times Was thanked: 555 time(s) in 465 post(s)
1. With Windows 10, you had to use either 100% or the default for Text Size -- I forget which. In Win 11, under System/Display/Scaling, you can change text size. I did so with no problems. There is a CUSTOM SCALING, which is not recommended. Make sure that is turned off. I tried turning it on, but it wanted me to sign out and back in, and I was in the middle of this post, so didn't do it.
2.Sounds like a video driver refresh issue. See if there is any update for that. I have a new version of VFP 10, and there are different video options with VFP 10 that I will read up on.
Sorry I don't have more.
