Groups: Administrators, Beta Testers Posts: 3,267  Location: Auburn, GA Thanks: 1147 times Was thanked: 555 time(s) in 465 post(s)
Your screen shot shows em93 & DN36. There is no EM63. OK, I guess when you say em63 you mean em93. So check to see if you need EM93 and EM93 VUCC.
Regardless, they shouldn't be showing up in lower-case. I tried to reproduce this by posting a test spot with the same comment em93<>fn13, and mine shows in upper-case. I am running LOGic with DX Summit and have a bunch of grids. They are all lower-case in the comment, but upper-case in the GRID column. I also did a test spot with upper-case in the comment, and the grid column was still upper case.
I would like to reproduce it so I can fix it.
What version of LOGic are you running? We changed the code that LOGic uses to extract grid squares and figure out which one corresponds to the station being spotted. It's been a while, but after we started switching to .Net.
