Report Error
ct1bxx
#1 Posted : Friday, October 7, 2011 10:10:36 AM(UTC)
Hi,
My good friend - CT1ZW Júlio, have had a problem while trying to print qsl labels.
It had work always well but some days ago a problem occurred.
When he try to print labels for qsl cards he receive 3 messages and Logic do not close well!He tried to make other reports: awards and others, the error always appears.
The messages are:
"Object GLOBAL is not found"
"GLOBAL is not an object"
"Cannot clear the object RUNREPORT because it is in use"
He have cleaned indexes, same problem, than he make a new instalation and he got same error.
Could you please help us to corrcet the problem?
If necessary I can send pictures showing the error messages
Many thanks for your help
Manuel Fernando - CT1BXX
#2 Posted : Friday, October 7, 2011 4:12:49 PM(UTC)
Hi Manuel:
What report is he using? The exact name pse. Then I can try it here.
Tnx &73,
ct1bxx
#3 Posted : Monday, October 10, 2011 9:41:45 AM(UTC)
Hi Manuel:
Tnx &73,
Hello Dennis,
The problem happens with all reports.
Today Júlio have made a test with two reports than he have not tested before and the problem happens, no matter the report he chooses the error happens.
In my computer all reports work well.
Today Júlio have a tested with those one, but always the same result. It happens since a week ago, before it all work fine
"Cards needed Land Scape"
"Award CNT"
73's
Manuel Fernando
ct1bxx
#4 Posted : Friday, October 14, 2011 8:29:28 AM(UTC)
I have good news from Júlio regarding the report errors...
Everything is working well as before !No more errors!
Monthly Júlio makes a defrag on hard disk.
Today he makes the defrag , after that, he tests reports in Logic, and ... without any other explanation or action, the reports works well as before.
Sorry for trouble caused with Júlio´s problem,but now we are happy to inform that all is working fine.
73's
Originally Posted by: ct1bxx Go to Quoted Post
Hi Manuel:
Tnx &73,
Hello Dennis,
"Award CNT"
73's
Manuel Fernando
#5 Posted : Friday, October 14, 2011 2:31:01 PM(UTC)
That's good, because I have no idea. I was going to suggest installing the latest update again.
Guest (17)
