FTdx101MP Interfacing
K4ZO
#1 Posted : Tuesday, August 9, 2022 1:29:25 PM(UTC)
Was thanked: 8 time(s) in 6 post(s)
Posted this problem before, no reply or feedback. Sent several support emails. No reply. Pretty much a waste of time and money to purchase a support subscription.Mad
#2 Posted : Tuesday, August 9, 2022 3:30:49 PM(UTC)
Sorry you are not being helped.
I checked for previous posts on this board from you, and there are none. I could have missed an email, but not several. (Make sure you are using the email on our web site http://hosenose.com) I checked our records and see that you are a long-time customer. Not sure what happened.
Please post the details of your problem here, and I will help. You may also call me at 770-307-1511. If no answer, please leave a message.
Tnx for using LOGic,
K4ZO
#3 Posted : Wednesday, August 10, 2022 7:04:33 AM(UTC)
Here is the original post
#1 Posted : about a month ago
ATTACH
EDIT
DELETE
QUOTE
Was thanked: 6 time(s) in 4 post(s)
I have a new FTdx101MP. I use the USB port to control the rig. It is assigned COM5 and it works fine and Logic controls the radio fine AS LONG AS the radio is on when I start Logic. If I start Logic with the radio off (as I often do to upload logs or do other DB maintenance) the program blows up. I have to physically disconnect the USB cable from the rig or the computer, shut down Logic (usually with task manager because it's locked up or not responding) and then restart Logic with the USB cable disconnected. The OS is WIN10pro. Never had this issue with my old radio which used serial port COM3.
This is very inconvenient and should not be necessary. I should just receive a message that COM5 timed out or something like that. Any help would be appreciated.
Bruce K4ZO
Three emails to follow up were sent. The first did not use the web site. The other two did however, they came from bmgragg@bellsouth.net instead of k4zo@bellsouth.net. Perhaps this is where the problem was. The workaround for this problem is just to unplug the USB cable from the rig to use Logic with the rig turned off.
Bruce K4ZO
#4 Posted : Wednesday, August 10, 2022 11:10:04 PM(UTC)
Sorry Brue--I clicked your callsign and then ALL POST BY USER, and nothing comes up, which is obviously wrong since you have two posts in this thread. Something else to fix.
I put a timeout on serial port transmits. Hopefully that will fix it. I have some Bluethooth/Serial ports for a GPS or something, and when I accidentally set LOGic to use one of those, it would lock up. That is fixed, so hopefully it will fix the problem with the rig being off. It is in the 10.0.8 update release today. Let me know please.
Again, I apologize. I appreciate your presistence and graciousness.
