My mistake. Sorry.
To work around it, type *.* in the filename field of the file selector. Then it will let you select ANYTHING. I will clean this up. Thanks for pointing it out.
BTW, if 4 instances of WSJT-X isn't enough, open a second log form, and you get four more.
Tnx for using LOGic.
PS We are on 10.0.7 now.
