Auto ADIF Logging from GridTracker_QSO.adif file
K4MV
#1 Posted : Friday, July 8, 2022 8:23:47 PM(UTC)
I am running Version 10.0.3 of Logic. I have an interest in being able to "Auto ADIF Logging" from the GridTracker "GridTracker_QSO.adif" file. Since all QSO's using GridTracker post to this ADIF file I'm hoping this will enable me to auto log to Logic when I may have more than four instances of WSJT-X open (using more than four slices in my FlexRadio). My challenge is that the "GridTracker_QSO.adif" file has an "adif" extension and not a "adi" extension. As a result, Logic will not enable me to "see" and select the "GridTracker_QSO.adif" file since only files with the "adi" extension are shown when looking for an ADIF file to add. Is there something different about ADIF files with an "adif" extension than ADIF files with an "adi" extension? If not, how can I find and select an ADIF file with "adif" extension so that the file can be added to the "Auto ADIF Logging" tab in order to auto log WSJT-X contacts made using GridTracker?
Mark
K4MV
#2 Posted : Sunday, July 10, 2022 6:49:23 PM(UTC)
My mistake. Sorry.
To work around it, type *.* in the filename field of the file selector. Then it will let you select ANYTHING. I will clean this up. Thanks for pointing it out.
BTW, if 4 instances of WSJT-X isn't enough, open a second log form, and you get four more.
Tnx for using LOGic.
PS We are on 10.0.7 now.
