On-demand QSL label printing
#1 Posted : Wednesday, April 25, 2012 11:25:05 AM(UTC)
Hi
someone can tell me something about the file .rep to use in on-demand qsl label printing?
If I can turn this option from the main logform the qsl or the label to be printed refers to the QSO in the logform or QSOs that have been made ​​with that same callsign?
This option is only used to print the qsl at the end of each QSO? Then the .rep module must be for a single QSO and in this case just finished printing the qsl the QSO is updated as printed QSL?
In Tools\Setup\On-demand QSL label printing menu i changed the report with an existent i using to print qsl and i get an "variable 'ALL_MSG' is not found" error message.
Where can i get a .rep module to see how work Logic in this case?
Thanks in advance to all those who can help me
#2 Posted : Thursday, April 26, 2012 9:14:19 AM(UTC)
First of all, let me apologize for not documenting this in Help. I just now realized this.
This is designed to print a QSL and/or Address label for the QSO currently displayed on the log screen. It is primarily useful for those with one of those little label printers.
You cannot use just any report here. They have to be designed for on-demand use. The only report that works is the one provided -- one each for address and QSL.
Print those, and if you want to make changes, modify the default reports and save them under a different name.
#3 Posted : Thursday, April 26, 2012 12:10:06 PM(UTC)
I understand but I can not find, in the report folder, the file you told me. Where can I find it?
Thanks for help.
73's de IKØCHU
#5 Posted : Tuesday, August 7, 2012 11:11:57 AM(UTC)
please where can i find the report file that works with the On-Demand QSL label printing option?
What is the real file name to search in the report folder?
Sorry but i want to realize a second printing line working as well the first only for specific stamps without change everytime the qsls or labels.
Thanks de IKØCHU Mauro
#6 Posted : Wednesday, August 8, 2012 5:22:51 PM(UTC)
Go to tools/on-demand QSL Label Printing
This should be set to
REPORT\ON-DEMAND QSL LABEL.REP
REPORT\ON DEMAND ADDRESS LABEL.REP
(this is referring to the REPORT folder inside the LOGic install directory, to answer your question).
Click LOG\Print Labels to print the labels.
If you want to make changes, use the report writer as usual. I recommend saving your labels as a different name.
Note that you cannot use any label report for on-demand. Start with ours.
#7 Posted : Wednesday, August 8, 2012 8:52:34 PM(UTC)
Hello Dennis,
thanks for the answer. My problem is not how to use the option of printing the report on demand, but the fact of not having, in all my hard disk, the reports files that you mention be provided with Logic9. It's possible to have a link where I can draw on these report files or you send them to me in the way of proving this print option?
#8 Posted : Sunday, August 12, 2012 9:47:50 PM(UTC)
Oh, sorry. They are attached to this message.
Not sure what happened. I just checked my master and it is there. Anyway, if anyone else is missing it (or not missing it for that matter) pse let me know.
On-Demand.zip (7kb) downloaded 1 time(s).
