Info from QRZ and DXCC description
N7IP
#1 Posted : Sunday, April 22, 2012 10:09:40 AM(UTC)
Was thanked: 22 time(s) in 22 post(s)
Hi Dennis. Two follow-ons requests from previous posts.
1. Info from QRZ subscription still does not come into Logic correctly:
- The city code info is deleted when it follows the city name (typical of non-US addresses). UA4FCJ is one random example of this.
- IOTA info does not go into the log
- "QSL via" info does not go into the log
2. DXCC description is now limited to 16 characters. Can we expand that to be same as Logic 8?
Bob
#2 Posted : Monday, April 23, 2012 8:14:43 AM(UTC)
Was thanked: 526 time(s) in 439 post(s)
Hi Bob:
Unfortunately the data does not come with separate fields for city, postal code, etc.
A "secret" diagnostic tool is to shift-rightclick the address line in the callbooks form:
Penza, pr. Stroitelei, 130-232 Russia
So first of all, is Penza is the city, or is it pr. Stroitelei? Or Penza pr. Stroitlei?
Comparing to a Canadian, if pr. Stroiteli is actually a province, we are consistent apart from an extra comma:
FORT MCMURRAY, AB T9K 2C4 Canada
At any rate, I will look into just copying that whole line less the country to to the CSZ line of the address field of the log. I am appparently reconstructing it from City, State, Zip and that is obviously not a good idea.
The callbook interface does not currently support VIA or IOTA. Not a QRZ Subscription problem per se. I will add it.
The "DXCC DESCRIPTION". Where do you see this? What form is it on?
N7IP
#3 Posted : Monday, April 23, 2012 9:08:20 PM(UTC)
Dennis, the truncated DXCC Description appears in the spot log.
Bob
N7IP
#5 Posted : Monday, April 23, 2012 9:16:12 PM(UTC)
Dennis, F5MUX is another random example of the location of a city code in the address. In fact, you can look at any non-NA address for how the city code is used--it appears either before or after the name of the city.
Bob
#4 Posted : Thursday, April 26, 2012 9:28:06 AM(UTC)
Bob
Ok, understand. Will make it longer. Meantime you can do it yourself.
Close the spot log. Go to tools/advanced/database commands. Follow the screen shot.
Tnx 73,
N7IP
#6 Posted : Thursday, April 26, 2012 2:29:18 PM(UTC)
Dennis, I followed the screen shot and verified the width is now 24. But the spot log display is still truncated at 16 characters.
Bob
#7 Posted : Tuesday, May 1, 2012 4:18:17 PM(UTC)
The old spots aren't going to magically fix themselves, but the new ones should not be truncated unless they are over 24 character.
N7IP
#8 Posted : Tuesday, May 1, 2012 7:27:10 PM(UTC)
Dennis, new spots are still being truncated...
#9 Posted : Wednesday, May 2, 2012 2:10:31 PM(UTC)
Ok, to how many characters is it being truncated? Double-check your work. I made a dest spot of 3B6AA whihc is AGALEA & ST BRANDON 19 characters, and it is OK.
