Logic9 user1 field problem
ae4wg
#1 Posted : Friday, April 20, 2012 1:24:20 PM(UTC)
I was trying to add several user defined fields to Logic9 last night, and when I got the "ANT" field to show up on the "main" log it took the place of the "CQZ" field in the user1 field, I removed the "ANT" field and all I see on the "main" log where the CQZ was, is user1 (both the icon name & in the icon box).
I am wondering how to get the CQZ back into this position.
Also if Igo to the "test" log the CQZ box populates with the QSO input, so I know the CQZ function still works. I can put input data on either the "test" or 'main" log screen, but only view it on the "test" log.
Any help would be appreciated.
#2 Posted : Saturday, April 21, 2012 7:43:12 PM(UTC)
Just click the first dot (corresponding with user1), then double-click CQZ in the list to the right. See the other post in this section:
http://hosenose.com/Foru...t-Mode-to-Log-Form.aspx
By default only five user-defined fields are shown on the log form. If you want more you have to unhide them. See sect 5.2 and Sect 12 expecially 12.4, then let me know if any questions.
