invalid mode FT8
N7IP
#1 Posted : Monday, April 11, 2022 6:12:52 PM(UTC)
In the spot log, When I set rig on an FT8 entry, I get the error "attempt to set invalid mode FT8", yet FT8 is a valid mode in the mode table. How do I fix this?
Thanks, Bob, N7IP
WN4AZY on 4/12/2022(UTC)
#2 Posted : Tuesday, April 12, 2022 7:16:37 PM(UTC)
It is trying to set the radio to FT8. Of course there is no such mode on the rig, hence the error. I am in the process of designing a cleaner solution to this. Probably a new column in the Modes table that controls the mode sent to the rig.
N7IP
#3 Posted : Tuesday, April 12, 2022 7:25:16 PM(UTC)
How do I deal with this in the meantime?
#4 Posted : Friday, July 15, 2022 3:05:28 PM(UTC)
Sorry for the delay on this. Will get back to it.
N7IP
#5 Posted : Saturday, September 17, 2022 5:04:32 PM(UTC)
Hi Dennis. It's been 5 months now. I'm still dealing with this error. Could you update us on your plans for a fix?
Thanks, Bob
WN4AZY on 9/21/2022(UTC)
#6 Posted : Wednesday, September 21, 2022 6:32:01 AM(UTC)
Thanks for the reminder. As a result, I have begun coding this. It will be in the next update.
I apologize for the delay.
#7 Posted : Wednesday, October 19, 2022 6:25:29 PM(UTC)
Here it is!
http://distribution.hose.../logicupdate_10.0.9.exe
Please consider it to be beta. I had to update to .net framework 4.8, and also changed the way frequency-to-band lookup works. Any problems, just put 10.0.8 back.
In Tools/Setup/Modes is a new column RIG MODE. So for instance look for FT8 in actual mode, and put USB in RIG MODE. From now on, when you try to set the rig to FT8, it will send USB to the rig.
Let me know if any problems.
Thanks again for your patience.
