Adding more lines to a QSO label
K7PDW
#1 Posted : Wednesday, March 23, 2022 3:26:00 PM(UTC)
DAVE
I have changed my labels to a larger size on my Dymo LabelWriter 450. There is room for at least six QSO but the label report only prints 3 QSO and then starts a new label. How do I make it print more QSO per label?
#2 Posted : Wednesday, March 23, 2022 7:05:10 PM(UTC)
LOGic only supports 4 QSOS, but it would be easy to change from 3 to 4.
Modify the report. Select the COMMAND SCRIPS on the top, and BEFORE RUN on the bottom. Change the first line from
lblmult(global.report_ref.selectexp, 3) && function supports 2, 3, or 4 QSOs per label
to
lblmult(global.report_ref.selectexp, 6)
Ignore the comment. LOGIc supports 8 QSOs per label
Make the page area larger by double-clicking the DETAIL bar.
Copy and paste the last row of fields to make a new row. You can multi-select with Shift-Click. Repeat to make the 5th row & 6th row.
Now double-click each new field to change the field names. For instance, change day(qso_date3) to day(qso_date4) on the 4th row, day(qso_date3) to day(qso_date5) on the 5th row, etc.
For more info, see
https://www.hosenose.com...port-modifications.aspx
K7PDW on 3/24/2022(UTC)
