Adding Membership database
#1 Posted : Sunday, December 19, 2021 5:03:56 AM(UTC)
How is it going? I hope all is well.
In the past, even recently, I have created membership archives such as MNG you see in the figure.
Now I can't do anything anymore because the archives are created (RDA and QSL) but it is not listed in the form at the top left like all the others.
In this way, the data does not interact with the logform both during the insertion phase in real-time and when using the FIX QSO.
Is there something wrong that I cannot understand or is there a maximum number of membership archives ???
Thanks Mauro CHU
#2 Posted : Sunday, December 19, 2021 10:58:44 AM(UTC)
Good to hear from you. We are doing well thank you.
Please try adding QSL, RDA, etc to toos/setup/log fields. Make sure that MEMBERSHIP is checkmarked on the Membership tab.
Merry Christmas!
#3 Posted : Monday, December 20, 2021 9:15:43 AM(UTC)
Thanks to the immediate response. I had already done what you suggested. I also changed the tag for membership by adding # as the RDA # so as not to confuse it with the RDA which contains the district values. Nothing has changed. The same thing happened to me with the WAIS which is not updated automatically. Now let's spend Christmas and then talk about it calmly. A happy Christmas to you and Fe. 73 de IKØCHU Mauro Santa Claus hihi
WN4AZY on 12/21/2021(UTC)
#4 Posted : Monday, February 7, 2022 7:23:22 AM(UTC)
while I am processing RDA membership database a strange thing happens to me.
I have over 4000 Russian callsigns and most of them got to know their RDAs. I created the dbf and imported it into Logic.
Why are always and only 2280 calls loaded?
I also made membership archives of over 15,000 calls and never had any problems.
The structure of the DB is as follows:
Field_name Call Value
RDA R0CAF HK-02
#5 Posted : Monday, February 7, 2022 9:56:13 PM(UTC)
Hi Mauro--
The only thing I can think of is that there are duplicate calls in your .dbf.
Send me your .dbf and I can figure it out.
#6 Posted : Tuesday, February 8, 2022 7:01:58 PM(UTC)
I am attaching the .dbf file that I obtained by processing an excell file where I can do simple operations.
I already confirm that there are double calls but they have a different RDA value and in any case there are not many to justify the difference from 4029 records to 2280 transferred in Logic.
Apart from this particular problem I don't understand why the membership function of RDA doesn't work like the one that type ASC, SEZ, WAIP. In fact, WAIS does not work automatically in filling fields either.
I can't understand what the difference is. The thing for the WAIS and RDA does not work even with the Fix Qso related to the single qso.
Now I am working on a huge archive of Russian calls by merging smaller singles and trying to eliminate the doubles both Call and RDA. Then I will let you know.
Ultimately apart from the lower number of data it would be interesting if the RDA field filled in automatically like the other Italians. To do this you need specific programming or if it works with a membership should it work with all those that can be created?
Excuse the inconvenience and consider that it is not of vital importance so take your time and if you think it can be of common use.
73 de IKØCHU Mauro
RDAMEMB.dbf (79kb) downloaded 153 time(s).
WN4AZY on 2/9/2022(UTC)
