10.0.4 Install SlimDX Runtime Error
#1 Posted : Tuesday, January 11, 2022 9:03:44 AM(UTC)
Just downloaded and installed new version 10.0.4 and the installer popped up a SlimDX Runtime Error saying it did not install as expected. LOGic did install and looked normal while launching, version is 10.0.4 and has the new features. Stability unknown but will be running all day.
v10.00.04-20220110-SlimDX Runtime Error.png (9kb) downloaded 167 time(s).
WN4AZY on 1/11/2022(UTC)
#2 Posted : Tuesday, January 11, 2022 9:10:20 PM(UTC)
The SlimDX handles spot announcement. There is no change to that or how it installs with this release. I have seen that error before. If it gives you any problems just reboot and reinstall 10.0.4.
K8ZM on 1/11/2022(UTC)
#3 Posted : Tuesday, January 11, 2022 11:35:38 PM(UTC)
Ok, thanks...
I tried another download/install after a reboot just in case a glitch occured but the result was the same with the installer popping up the same error. If anything starts acting abnormally I'll report back.
#4 Posted : Wednesday, January 12, 2022 3:57:18 PM(UTC)
I tried it here and no problems. Also no other complaints. So don't know what is going on.
You can download it here
http://distribution.hosenose.com/public/
and manually install it. See if you get the same error.'
What LOGic uses it for is audio spot announcement. Click the TEST button on the Announcement tab of the spot log.
#5 Posted : Wednesday, January 12, 2022 4:28:02 PM(UTC)
I'll grab your SlimDX and try a manual install. My version is the same and the announcement works, weird it would say it "didn't finish installing as expected", I even turned off the Virus software.
Thanks for the link, I'll let ya know if it still errors.
Happy New Year to you guys !!
#6 Posted : Thursday, January 13, 2022 12:21:26 AM(UTC)
FYI - Ran the SlimDX installer and selected Repair (only other choice was Remove), sadly it doesn't report what it fixed but it did "Finish". Regardless, re-installed LOGic v10.0.4 and no more runtime error, so it did fix something.
Thanks again Dennis !!
73 de Brad, K8ZM
#7 Posted : Tuesday, February 22, 2022 9:20:56 AM(UTC)
Hi Dennis, hope all is well !!
Downloaded v10.0.5 via LOGic Updater, installed (retained copy), at the conclusion LOGic threw the exact same SlimDX Runtime error as it did in v10.0.4. Same as last time, I had to manually download and run the SlimDX Runtime Installer which "repaired" it then re-ran LOGic's installer which ran without any SlimDX Runtime error. Any idea why SlimDX Runtime is throwing this error, hate to have to do this every update.
#8 Posted : Tuesday, February 22, 2022 9:39:49 AM(UTC)
Sorry, I haven't found any new info on this error.
What happens if you simply ignore the error during install, and continue? Or is the "runtime error" when you are trying to use logic, not when installing? If so, I don't know why installing would mess up the currently-installed SlimDX. Call me and I can log in and take a look. I might see something.
#9 Posted : Tuesday, February 22, 2022 12:10:54 PM(UTC)
The runtime error occurs at the tailend of LOGic's install. I didnt launch LOGic after the install this time, but I did "ignore" the error during the v10.0.4 update when it first occurred. LOGic seemed to run fine then and I let it run for 24hrs with nothing appearing to be broke. This update I just ran the SlimDX installer immediately after LOGic threw the error. Here are some event logs from the time LOGic v10.0.5 was installed this morning when I got the error;
8:50:03 Information - MSinstaller Event ID 1040: Beginning a Windows Installer transaction: C:\Users\Brad\AppData\Local\Temp\is-QM37K.tmp\SlimDX Runtime .NET 4.0 x86 (January 2012).msi. Client Process Id: 996.
8:50:03 Information - RestartManager Event ID 10000: Starting session 0 - ‎2022‎-‎02‎-‎22T13:50:03.212350500Z.
8:52:06 Error - MSinstaller Event ID 11729: Product: SlimDX Runtime .NET 4.0 x86 (January 2012) -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action InstallDirectX, location: C:\Users\Brad\AppData\Local\Temp\DirectX Redist\DXSETUP.exe, command: /silent
8:52:06 Information - Msinstaller Event ID 11729: Product: SlimDX Runtime .NET 4.0 x86 (January 2012) -- Configuration failed.
8:52:06 Information - Msinstaller Event ID 1035: Windows Installer reconfigured the product. Product Name: SlimDX Runtime .NET 4.0 x86 (January 2012). Product Version: 2.0.13.43. Product Language: 1033. Manufacturer: SlimDX Group. Reconfiguration success or error status: 1603.
8:52:06 Information - Msinstaller Event ID 1042: Ending a Windows Installer transaction: C:\Users\Brad\AppData\Local\Temp\is-QM37K.tmp\SlimDX Runtime .NET 4.0 x86 (January 2012).msi. Client Process Id: 996.
This seems to be the end of any event logs during the initial install of LOGic v10.0.5 relating to SlimDX.
Not sure if this offers any clues but figured worth posting.
WN4AZY on 2/24/2022(UTC)
