Selecting QSOs with pictures
WD4ASP
#1 Posted : Tuesday, December 28, 2021 6:34:20 PM(UTC)
Not sure if logging is the right place for this question but here goes anyway.
Is there a way to select QSOs with pictures? I looked at the Help section but did not see any information about it.
Of course I could have missed it as well. If there isn't a way to do that then would it be possible to add a field in the Filter selections.
Then a print option of whether to print the picture, the QSO information, or both.
If you end up adding a field for the pictures you might also want to consider adding fields for Notes, Address, and Bio.
Fred
#2 Posted : Wednesday, December 29, 2021 3:47:24 PM(UTC)
Hi Fred:
Unfortunately there is no way to search for QSOs with pictures. They are off in another file (log_pictures), so do not show up in the Filter screens. I will investigate doing this. Thanks for the idea!
Notes and Addresses ARE in the log field, and you CAN search on them. Bio is the same deal as pictures. So if I add pictures, I will add at least the ability to select QSOs with or without bio.
Happy New Year!
WD4ASP
#3 Posted : Sunday, January 9, 2022 9:19:25 AM(UTC)
Sorry it took me so long to get back to you on this. I understand the issue about being in a different file.
So looking at the pictures directory it is not easy to determine which pictures are associated with each call. Would it be possible to prepend or append the call to the picture file id?
Fred
