Q65 mode will not upload to LoTW
W8OI
#1 Posted : Tuesday, October 19, 2021 8:03:08 AM(UTC)
I used the mode Q65 (from the WSJT-X program) for the first time yesterday. I added it to LOGic's mode list but LOGic will not upload it to LoTW. When I try to upload, I get LOGic's error message that says "Invalid mode (Q65 on line 27)." What am I doing wrong, please?
#2 Posted : Tuesday, October 19, 2021 3:29:43 PM(UTC)
Currently LoTW does NOT recognize Q65 as a mode.
FWIW, you can have TQSL convert your Q65 contacts to DATA on the fly.
In the TQSL program, click on 'File' in the top bar.. Then choose 'Display or Modify Preferences'.
Now click on the ADIF Modes tab. There you can map Q65 mode to DATA mode. After that, when you upload using TQSL, it will change all your Q65 contacts to DATA as they are uploaded so they won't be rejected. The .adif file on your computer will remain unchanged so all your Q65 contacts will still show as Q65 contacts.
73 Kyle
WN4AZY on 10/20/2021(UTC)
W8OI
#3 Posted : Tuesday, October 19, 2021 7:19:19 PM(UTC)
Kyle, I tried that without success. I chose data as resulting TQSL mode and Q65 as my ADIF mode. I got an error message saying "this mode definition conflicts with a standard code definition for Q65." Did I do what you suggested?
W8OI
#4 Posted : Tuesday, October 19, 2021 7:47:51 PM(UTC)
Never mind, Kyle. I discovered the problem. In LOGIC Mode Setup I needed to type Q65 not only into the "actual mode" column but also into the "ADIF Mode" column as well. That fixed it. But thanks for your willingness to help.
2 users thanked W8OI for this useful post.
WN4AZY on 10/20/2021(UTC), wa4pgm on 10/21/2021(UTC)
