Getting the COM port correct so Logic will start.
KA1J
#1 Posted : Sunday, September 12, 2021 9:38:19 PM(UTC)
I'm about to fire up the K4 but I have a concern when it comes to starting Logic. I need multiple ports. The radio creates one but then I need ports for Logic, MMTTY, N1MM JTDX WSJT-X (I don't recall if the USB winkey creates its own). I used to use Larry Phelps LP Bridge but it didn't give enough virtual ports. I finally bought Win4K3 just for the virtual ports it permitted. WIn4K3 does not work with the K4. There is supposedly a K4 version being worked on. With that, I'll have the needed ports again.
So... When I start Logic it requires I either have it set up with no port, or with a port selected. No port selected, logic starts rapidly but there is no connection to the radio. If I indeed have a port selected but that port is incorrect or there's a problem with the port, logic hangs during startup (The last thing to appear is the frequency display but it stops and is greyed out) while looking for the port and will not continue loading. In the same vein, if I go to tools setup and make a mistake with selecting a working port, logic restarts/resets itself and again, it will hang without the named port working.
How can I get Logic to open if there is a port conflict and Logic won't finish coming to the desktop?
Thanks!
Gary
#2 Posted : Monday, September 13, 2021 2:41:53 PM(UTC)
Hi Gary:
Sorry for the problem. LOGic SHOULD report an error and continue. Or more precisely, Windows should report an error to LOGic and LOGic should forward it. I'll experiment.
To get into the program: The port assignment is in the .INI files. c:\program files (x86)\LOGic\Radio9.ini. Just manually edit it with Notepad. Change
Port=COM4
to simply
Port=
That will prevent LOGic from trying to open that port.
You might have to copy radio9.ini onto your desktop, edit it, then copy it back to c:\program files (x86)\LOGic
Tnx for using LOGic.
KA1J
#3 Posted : Wednesday, September 15, 2021 10:56:30 AM(UTC)
Thanks for the info, I'll do that.
Cheers & 73,
Gary
KA1J
1 user thanked KA1J for this useful post.
WN4AZY on 9/15/2021(UTC)
