Error in updating to LOGic 10.0
N0AT
#1 Posted : Monday, August 23, 2021 3:31:48 PM(UTC)
Today I tried to update to LOGic 10.0. I keep getting the following error:
Program error
Variable is not found
USERFLDS2 is not found
I was not able to ignore the error until after I deleted all the index files.
#2 Posted : Wednesday, August 25, 2021 9:28:28 AM(UTC)
Yes, that is the new field to hold the additional userfield data. It normally gets installed whenever you do a Clean and restart LOGic. Installing the update should force a Clean, which basically deletes all the .cdx files. So not sure what happened.
Anyway, you did the right thing. I trust all is well now?
N0AT
#3 Posted : Wednesday, August 25, 2021 11:46:02 AM(UTC)
Yes, all is well now.
I have multiple logs in multiple directories. It looks like the installer didn't know about the index files in the other directories. I manually deleted all the index files and all is well.
73 de Ron N0AT
1 user thanked N0AT for this useful post.
WN4AZY on 8/30/2021(UTC)
#4 Posted : Monday, August 30, 2021 12:42:56 PM(UTC)
Ok, I guess I need to make a better way to CLEAN alternate databases!
