Groups: Administrators, Beta Testers Posts: 3,246  Location: Auburn, GA Thanks: 1130 times Was thanked: 549 time(s) in 459 post(s)
Yes, that is the new field to hold the additional userfield data. It normally gets installed whenever you do a Clean and restart LOGic. Installing the update should force a Clean, which basically deletes all the .cdx files. So not sure what happened.
Anyway, you did the right thing. I trust all is well now?
