Setting up Report writer
G0HSA
#1 Posted : Sunday, April 1, 2012 7:21:53 AM(UTC)
I use Avery J8160 sticky labels to print qso labels for my cards.
The dimentions of the labels are 63.5 x 38.1 mm and are 3 labels across and 7 labels down.
I have just changed the height of the label template multipul qso labels 4 qso's per label 3 labels across and done a test print. The left margin of the test print has cut off part of the date. How can I remedy this situation.
73 de Andrew G0HSA Confused
#2 Posted : Tuesday, April 3, 2012 9:19:51 AM(UTC)
Hi Andrew:
Modify the report, click the Report-Layout window to make it active, then click File/Page Setup on the menu bar. Increase LEFT MARGIN.
In case that doesn't work, you can use the mouse to lasso all items in DETAIL, and drag them to the right a bit.
Let us know if this does not resolve it.
