Massive data change command
#1 Posted : Monday, June 21, 2021 2:34:54 PM(UTC)
Hello everybody.
I launch a call for help and hope someone can help me.
I explain the problem.
I have created a new field called QOB acronym of Qsl Official Bureau and relative archive to be able to print my QSLs for the Bureau without having to check them after they are printed.
For example, with the procedure of massive archive changes, I added the LU value in the QOB field to the DXCC LU. Similarly for DXCC GW QOB = G DXCC GM QOB = G etc etc.
With the same criterion I elaborated the American CALLS proposing the call area as a filter element. Example DXCC K_, call contains 1, fill in the QOB field with W1 etc etc.
The problem arises with the call area 4 where I must also indicate the prefix with one letter and the prefix with two letters with the exclusion of KG4 and KP4.
Which command should I give to differentiate x4 with xx4 ????
I cannot find which wildcards to use, as long as this operation is possible.
Thanks to anyone who can give me a solution on the script to insert in the replace into massive change database command.
73's de Mauro IKØCHU
#2 Posted : Tuesday, June 22, 2021 2:07:05 PM(UTC)
There is a regular expression engine in .net that I could expose easily enough. But they are complicated.
This would probably be the easiest:
x4:
DXCC = "K " and at(CALL, "4")=2
(the 4 is in the second position.)
xx4:
DXCC = "K " and at(CALL, "4")=3
By the way, you could put these statements all in a .prg file in the UTIL folder to easily update the new QSOs at any time.
use log
replace userfields with tag_edit(userfields, "QOB", "W1") for NOT "QOB:" $ USERFIELDS and DXCC="K " and left(call,2)="W1"
replace userfields with tag_edit(userfields, "QOB", "W2") for NOT "QOB:" $ USERFIELDS and DXCC="K " and left(call,2)="W2"
replace userfields with tag_edit(userfields, "QOB", "KP4") for NOT "QOB:" $ USERFIELDS and DXCC="KP4 "
replace userfields with tag_edit(userfields, "QOB", "x4") for NOT "QOB:" $ USERFIELDS and DXCC="K " and at(CALL, "4")=2
replace userfields with tag_edit(userfields, "QOB", "xx4") for NOT "QOB:" $ USERFIELDS and DXCC="K " and at(CALL, "4")=3
Note the NOT "QOB:" $ USERFIELDS. It keeps a command from overwriting existing results. That way if you have commands that could possible conflict, put the one that takes precedence first.
IK0CHU on 6/22/2021(UTC)
