LOGic Forum
LOGic Support
Logging
Logging then ESC deletes DXCC field
Posts: 627 Location: Mentor, OH
Thanks: 151 times Was thanked: 241 time(s) in 216 post(s)
When entering a new QSO then deciding not to log it and hitting ESC to back out it, the DXCC field of the last logged QSO gets deleted. I think I posted this issue under Contesting some time ago but wanted to refresh that's its still an anomaly.
Running LOGic v9.1.27.
73 de Brad N8GLS
Thanks -- I missed the other post about it or forgot.
I was able to reproduce it once. Also got it to wipe the call out once. But most of the time it works. Live with it. Just kidding. I think it might have something to do with if there is a blank record left in the log from if you add a new QSO then abandon it by pressing {Esc}. I'll go thru that code.
Thanks for letting me know.
Ok, I can live with that...Hi Hi.
I never had a call get deleted, only the DXCC field. I was attempting a QSO on 17m and the band went dead, so hit esc and the previous QSO's field went blank. I re-input the DXCC entity and I remembered that I had done this a few times over a couple weeks. Now, what did I do with my keys ........???
73 de Brad
I totally forgot about this issue but it still exists. Just tonight I was about to log a QSO, hit Cntrl-N, pre-entered all the data in the logform then the band died so hit the esc key on the keyboard. All fine until I scrolled up in the browser window and the DXCC field from the last logged QSO was erased. Doesn't happen if you use the "undo" radio button in the logform, only from the keyboard.
Hope all are keeping warm, already 16 deg here.....brrrrrr !!
Brad, N8GLS
LOGic Forum
LOGic Support
Logging
