LOGic shows incorrect band when changing frequency
#1 Posted : Monday, January 18, 2021 12:45:53 AM(UTC)
After moving from one band to another, LOGic does not always show the correct band in the LOG -- MAIN window. I moved from 6m to 40 meters. Frequency shows correct but not band. As a result, it shows up incorrectly in the log as well. See attached pics
20210117 LOGic does shows incorrect band.PNG (33kb) downloaded 5 time(s).
20210117-2 LOGic shows incorrect band.PNG (22kb) downloaded 7 time(s).
WN4AZY on 1/18/2021(UTC)
#2 Posted : Tuesday, January 19, 2021 8:33:18 AM(UTC)
Is LOGic reading the freq from the radio? Is it consistently wrong?
I would look at tools/setup/bands and see if anything is amiss there.
#3 Posted : Thursday, January 21, 2021 8:41:41 AM(UTC)
Dennis, this usually happens when I change from WSJT to LOGic and I turn "Turn on or reset radio and rotor interfaces".
#4 Posted : Thursday, January 21, 2021 11:54:44 PM(UTC)
Dennis, it has happened again. I was on FT8 using WSJT (with LOGic also running), closed WSJT then turned on Radio and Rotor interface in LOGic. LOGic correctly picks up frequency from K3 but does not show correct band. LOGic also logs incorrectly the wrong band. This has not always been the case, but I do not know when it started.
20210121 LOGic shows incorrect band, correct frequency.PNG (32kb) downloaded 3 time(s).
20210121-2 LOGic shows incorrect band, correct frequency.PNG (33kb) downloaded 3 time(s).
WN4AZY on 1/22/2021(UTC)
#5 Posted : Sunday, January 24, 2021 11:04:08 PM(UTC)
I may have found the problem. I went to setup and found that "poling" was turned off. I turned it on and it seems to be ok now. I don't remember what I had it set to before, but I haven't changed it lately. Will advise if I have further problems.
#6 Posted : Monday, January 25, 2021 10:17:18 AM(UTC)
Ok, cool. What rig is this?
#7 Posted : Wednesday, January 27, 2021 10:32:08 AM(UTC)
K3 s/n 2324
WN4AZY on 1/27/2021(UTC)
Guest (6)
