Radio name not showing up in Log/SetUp
#1 Posted : Thursday, January 7, 2021 12:18:15 PM(UTC)
I just noticed in Log Form set-up under the Rig,Rotor and Terminal tab that under Radio there is no Rig #4 name even though my Rig #4 is the IC-705. If I hover the mouse over the main log form's radio buttons 1, 2, 3, and 4, number 4 shows "Select Radio 4 Icom-705 (COM29)", so its there. Could the log form setup under Radio just not have a path pointing to Rig 4's name ?? Pic attached.
Running v9.21.1, Radio 4 is active with rig control window on-screen and the rig name was entered in the general rig setup, same as for my other 3 radios.
73 de Brad, N8GLS
LogFormSetUp-Missing Radio(s).png (33kb) downloaded 148 time(s).
WN4AZY on 1/7/2021(UTC)
#2 Posted : Thursday, January 7, 2021 5:28:04 PM(UTC)
Fixed. It will be in the next update.
K8ZM on 1/7/2021(UTC)
#3 Posted : Tuesday, January 19, 2021 8:36:31 AM(UTC)
The fix is in the new 9.21.2 update. It is sort of beta, so.....
