QSLMSG in EQSL ??
OZ4CG
#1 Posted : Tuesday, December 15, 2020 2:13:54 PM(UTC)
Carsten Gjessing
Hi Dennis
Today I had a discussion with two other ham's about getting a QSLMSG on the outgoing eQSL's.
I can understand it is a complicated matter for users of other logsystems, and I told them, they should consider using LOGic9, which I think is state of the art regarding handling QSL's and awards etc.
I was sure, that the QSLMSG which is automaticly printed on the paper-QSLs, also was printed on my eQSLs.
Now I have checked it up, and can see, that I was wrong: it is NOT printed on my eQSLs!
Maybe it is a bigger job to make it do so, and then you should not give it priority, because it is not very important to me, and I can see, you have many other wishes from other users to handle, but if it only a minor thing, maybe you could fix it some time??
Just a humble question!RollEyes
With my best wishes for a merry Christmas and a happy new year to you and your family
Carsten / OZ4CG
#2 Posted : Monday, January 4, 2021 8:35:21 PM(UTC)
Sorry for the delay. I totally overlooked your post.
It would be a simple matter to export QSLMSG to eQSL. ANd it looks like eQSL accepts it. See
https://www.eqsl.cc/qslcard/ADIFContentSpecs.cfm
So just go to tools/setup/log fields...., navigate to the QSLMSG field, and go to the ADIF tab. Turn on Import and Export. You will probably want to EXPORT WHEN BASIC FIELDS....
OZ4CG on 1/5/2021(UTC)
OZ4CG
#3 Posted : Tuesday, January 5, 2021 4:25:31 PM(UTC)
Carsten Gjessing
Hi Dennis
Thank you very much for your answer. I have marked the posts as you mention, and will see the result in my next upload to eQSL, and let you know!
Thank for your allways great help
Best 73 Carsten / OZ4CG
Skærmbillede 2021-01-05 22.21.22.png (124kb) downloaded 131 time(s).
1 user thanked OZ4CG for this useful post.
WN4AZY on 1/6/2021(UTC)
OZ4CG
#4 Posted : Wednesday, January 6, 2021 9:11:51 AM(UTC)
Carsten Gjessing
Hi again, Dennis!
It works! Thank you again, Dennis!
