Error msg when launching LOGic 9.20.14
K4MV
#1 Posted : Monday, November 30, 2020 3:07:17 PM(UTC)
I recently upgraded to LOGic 9.20.14. Since the upgrade, whenever I launch LOGic 9 I get the message, "Error 1426 "OLE error code 0x80004005: Unspecified error." has occurred in program LOGICAPP.AFTER_INIT, line 35." I am then asked if I want to attempt to continue. If I select YES then all appears to load and work as expected (other than a problem with XML QRZ that you are already following up on). What might I need to do to get rid of this error message?
Mark
K4MV
1 user thanked K4MV for this useful post.
WN4AZY on 12/1/2020(UTC)
W8JY
#2 Posted : Tuesday, December 1, 2020 10:35:40 AM(UTC)
I am getting the same message. Once I click on yes, LOGic loads and works normally.
#3 Posted : Tuesday, December 1, 2020 3:38:53 PM(UTC)
Thanks for the report.
Please download and install it again.
If that doesn't fix it for some reason, you can go to tools/misc ham setup/General, and turn off OLE Server. Unless you are using TRX-Manager or controlling LOGic remotely from another program, may as well leave that off.
K4MV
#4 Posted : Friday, December 18, 2020 5:10:04 PM(UTC)
Reinstalling LOG9c 9.20.14 did the trick. The error message is no longer displayed.
Thanks....Mark
WN4AZY on 12/21/2020(UTC)
