Portable Logging Backup and Appending to Master log
NP3K
#1 Posted : Monday, September 21, 2020 1:05:02 PM(UTC)
Hello,
I have a laptop for Portable operations. I want to use it with a simple log window, backup when I'm done and then append that log to my main Log at home.
Is there a way that I can put a comment in the Comment window like: Working portable at XXXX and then have it automatically filled on the next entry/call?
This way when I append the portable log to my Main log, if I'm browsing my main log I know which call was from home and which was portable and from where.
Also, is there a fast way to delete the log from the portable log once I have backed up, so I can have it ready for my next adventure?
Thanks for your help.
Charlie NP3K
#2 Posted : Monday, September 21, 2020 2:10:51 PM(UTC)
For comments from the Main log window: Log>Setup>Copy from Prev QSOs
To delete log use: Tools>Miscellaneous utilities>Zap Log
73 Kyle
NP3K on 9/21/2020(UTC)
NP3K
#3 Posted : Monday, September 21, 2020 2:59:39 PM(UTC)
Kyle,
For comments from the Main log window: Log>Setup>Copy from Prev QSOs....it will only put the comments if its the same call. I'm looking to bring the comment when I hit the + key for my next call.
Zap is what I use to delete all, I was just wandering if there was a shortcut key, no biggie.
Thanks.
Charlie
NP3K
#4 Posted : Tuesday, September 22, 2020 2:26:30 PM(UTC)
OK, I figured it out.....go to
Log Setup Default
under FIELD I select COMMENT and under EXPRESSION you type in your what ever you want starting and ending with "
Charlie
1 user thanked NP3K for this useful post.
wa4pgm on 9/23/2020(UTC)
