Groups: Administrators, Beta Testers Posts: 3,259  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
Here is our correspondence. I suspect they are thinking of doing what WSJT-X is doing, and I am trying to steer them in that direction. If they do that, then it will work with LOGic without any changes. Tnx & 73, Dennis WN4AZY Quote:Hi-- Yes, I am referring to the latest version. I would like to see an interface similar to WSJT-X where QSOs are written to an ADIF file in real time. It works well and is used by several programs, and is fairly trivial to implement on the sending side. It is of course platform-independent. Adding this would increase the demand for MixW among existing users of these programs. I will watch for the update. Tnx &73, Dennis WN4AZY http://www.hosenose.comOn 10/14/2020 9:01 AM, MixW Team wrote: > > Hello Dennis, > > What version were you talking about? If about 3 then yes, it supports it, in 4 it is not yet, in the future such an interface will be added, but already of a different type with the possibility of cross-platform use. As soon as such an opportunity is added, I will definitely additionally report this in our group https://groups.io/g/MixW
> 11.10.2020 15:41, Dennis Hevener пишет: >> Is it still possible to interface MixW to other logging programs? MixW used to have a DDE interface, but now I am getting an error when I try to use it. Has this been removed? Is there some other way to interface to MixW? > -- > > Regards, > Alex Bilobrov /UT4ULP/ > Software engineer Rig Expert Ukraine Ltd > Telegram: AlexTimmi > Groups.io: MixW > E-mail: ut4ulp@rigexpert.com> Web: www.rigexpert.com> Fb: RigExpert
