LOGic Forum
LOGic Support
Import and Export
creating a cabrillo format section of the log so as to email for form.
Posts: 1 Location: Baton Rouge, La
how do I create an excerpt of a section of the log. I worked the RDA test this month and the organizer is asking for my log of that event in the cabrillo format.
Isn't there some sort of ADIF to Cabrillo converter available? Me I just use N1MM+ for contesting. 73, Allen N5XZ
Posts: 619 Location: Mentor, OH
Thanks: 150 times Was thanked: 235 time(s) in 212 post(s)
FWIW: I think this site has a downloadable converter for most every contest, RDA is one listed. Anyways, looks interesting, not sure if its "free". A Bing search resulted in more than a few others. http://www.contestlogchecker.com/
Someday I'll get into the Cabrillo templates (think they are just simple text files) and play around then try to configure a contest. I haven't played with the Cabrillo templates but am curious now how "hard" the process is for defining a contest complete with logform and Cabrillo export. Maybe a YouTube video is in order. 73, de Brad N8GLS
Posts: 467 Location: Missouri
Thanks: 100 times Was thanked: 157 time(s) in 139 post(s)
Go to tools/export and select Cabrillo format. 73 Doug W5GA
I believe the original post was asking how to export into cabrillo for the RDA contest, for which there is no contest logform (or cabrillo template) for. Unless I'm missing something you can't export via Tools/Export/Cabrillo Contest Format unless the logform and template for the contest exists, nor can one export a portion of their log in Cabrillo......right ??
Brad, N8GLS
LOGic Forum
LOGic Support
Import and Export
