not reporting marked QSO's correctly
#1 Posted : Friday, August 21, 2020 10:05:05 AM(UTC)
When uploading the latest batch of QSO's to LoTW, I saw that Logic reported marking one qso as uploaded. There were several more that were not reported, in spite of having the check mark in the LoTW sent box.
#2 Posted : Thursday, August 27, 2020 11:54:52 AM(UTC)
Thanks. It is fixed and will be in the next update.
I apologize to all for my absence. Things are OK here and I will be back soon.
Thanks & 73,
DH WN4AZY
w2zi on 9/4/2020(UTC)
#3 Posted : Tuesday, September 8, 2020 12:11:10 PM(UTC)
Hope all is well !! Thanks for the update. Downloaded/Installed on Sep 5 (Sat) and seems fine.
1) LoTW Uploaded record count now reports actual qty uploaded (Fullfilled)
2) LOTWRDATE & LOTWSDATE now checks to see if enabled before inputting the date(s). For those that don't want to consume character space in USERFIELDS they can uncheck "enable" for either/both field(s).
3) CW Ops membership download...have not tried yet.
No new errors (EventLog or otherwise) as a result of the other changes et al.
I still have a few other anomalies relating to windows that stay open and a couple questionable prefixes but will post those under an appropriate topic/category.
Thanks for the update !!
73 de Brad, N8GLS
WN4AZY on 9/8/2020(UTC)
#4 Posted : Tuesday, September 8, 2020 4:16:56 PM(UTC)
Someone else found a problem with ADIF import. Pse download & install again.
K8ZM on 9/9/2020(UTC)
