VE7CC login issue
N7IP
#1 Posted : Friday, July 10, 2020 4:02:22 PM(UTC)
Dennis, I can't get Logic to log into VE7CC. My setup is shown below:
prompt wait response
CALL: 5 MYCALL
LOGIN: 5 MYCALL
The following is the transcript of the login --->
Please enter your call:
*** Connected to VE7CC-1:
Greetings from the VE7CC-1 cluster.
Located near Vancouver BC
Running CC Cluster software version 3.121ap
* Please login with a callsign indicating your correct country *
* Portable calls are ok. *
New commands:
set/skimmer turns on Skimmer spots.
set/noskimmer turns off Skimmer spots.
set/ft4 turns on FT4 spots
set/noft4 turns off FT4 spots
set/ft8 turns on FT8 spots.
set/noft8 turns off FT8 spots.
also:
set/cw
set/nocw
set/rtty
set/nortty
set/psk
set/nopsk
set/nobeacon turns off spots for beacons.
set/beacon turns them back on.
For information on CC Cluster software see:
http://bcdxc.org/ve7cc/ccc/CCC_Commands.htm
AR User program now at ver. 2.447
login:
LOGic> Waited for CALL: to be sent by host, but it was not.
LOGic> Check Setup.
#2 Posted : Friday, July 10, 2020 4:13:00 PM(UTC)
I tried your setup here and it worked for me. Maybe VE7CC was having issues at the moment?
I used "login 5 mycall"
N7IP
#3 Posted : Friday, July 10, 2020 5:48:12 PM(UTC)
VE7CC is not having issues. This has been a problem with my copy of Logic for over a year. I'm just now getting around to trying to find a solution. Sometimes it connects and sometimes it does not. After it gets stuck, I can always successfully connect by hitting the connect button. Timing?
Bob
#4 Posted : Friday, July 10, 2020 6:29:49 PM(UTC)
When you have issues is it just with VE7CC or others?
Here's my setup
Address: dxc.ve7cc.net
Prompt: LOGIN
Seconds to Wait: 5
Response: mycall
Local Echo is checked but I usually uncheck it.
Use Prompt/response
N7IP
#5 Posted : Friday, July 10, 2020 10:05:08 PM(UTC)
Thanks for your comments. Yes, that is exactly my setup. I can immediately sign into other clusters but since the VE7CC problem does not happen on every attempt, it's hard to draw a conclusion from trying another site.
Bob
#6 Posted : Saturday, July 11, 2020 12:00:52 AM(UTC)
I too had problems with VE7CC logins. Now I use the VE7CC client, and have Logic log into that using 127.0.0.1. using configuration/ports/logging program in the VE7CC client. Problem solved.
#7 Posted : Saturday, July 11, 2020 12:07:09 AM(UTC)
I can't comment on the VE7CC node but my usual is the following:
address: CCC.N4ZKF.COM:7373
prompt: LOGIN:_
wait: 4
response: mycall
Only problems I've had are when my Internet is misbehaving.
73s, Don
