Changing Bands Causes Spot Filter To Shut Off
W3KL
#1 Posted : Saturday, May 16, 2020 7:01:03 PM(UTC)
Rig: FTdx9000MP
Version 9.20.5
I just noticed that whenever I change bands on my rig that the filter in the spot log is turned off. I've had this problem for years whenever I used the filter but never really tracked down the cause until today.
Is this a bug in the S/W or do I have something set incorrectly?
73, Jeff
W3KL
1 user thanked W3KL for this useful post.
WN4AZY on 5/19/2020(UTC)
#2 Posted : Sunday, May 17, 2020 1:21:26 PM(UTC)
Jeff,
I have an FT DX3000 here. Running LOGic 9.20.5 on Windows 7. I cannot reproduce your problem.
My spot log pre-filter is set at the default (SPOTBYCONT=GLOBAL.MY_CONTINENT) and my band table has "Process spots for this band" enabled for those bands I work. Perhaps if you switch to a band that's not enabled for spots, it closes the Spot Log form??
Guess this one will have to wait for Dennis.
73s, Don
W2ZI
W3KL
#3 Posted : Sunday, May 17, 2020 2:10:52 PM(UTC)
Originally Posted by: w2zi Go to Quoted Post
Jeff,
73s, Don
W2ZI
That's the pre-filter from the "Options" Tab. Try setting a filter from the "Spots" Tab and then change band.
Also, I notice if I set the DXCC filter to "<> K" to filter out posts from the continental US, it also filters out KH6 and KL7 which are different DXCC entities.
73, Jeff
W3KL
#4 Posted : Tuesday, May 19, 2020 12:44:36 PM(UTC)
He probably isn't referring to the prefilter, but the thing on the top right of the main spot page.
Jeff, what do you have typed in the filter field? Is CURRENT BAND checkmarked?
You can see the actual under-the-hood filter expression by holding the mouse pointer on top of the funnel. Does it change after you change the band on the radio?
W3KL
#5 Posted : Tuesday, May 19, 2020 3:06:29 PM(UTC)
Dennis. It's on the top left of the spots tab in my spot log (Has always been on the top left).
Yes it changes when I change bands when I hold the mouse pointer over the funnel. And the funnel changes from depressed (i.e., button pushed) to undepressed blue (button not pushed)
my filter: NOT 'FT'$COMMENT AND DXCC<>'K'
And current band is NOT checked
W3KL
#6 Posted : Friday, June 5, 2020 6:53:09 PM(UTC)
Dennis. Any ideas? Thanks W3KL, Jeff
#7 Posted : Friday, June 12, 2020 9:48:31 AM(UTC)
Thanks for reminding me. I will look into it today.
#8 Posted : Monday, June 22, 2020 2:15:43 PM(UTC)
Sorry taking so long on this. I reproduced the problem! That's usually half the battle.
#9 Posted : Thursday, June 25, 2020 3:51:31 PM(UTC)
Fixed. Get the new 9.20.7.
