10-10 Processing does not work
#1 Posted : Wednesday, August 19, 2026 4:13:53 PM(UTC)
I tried to import the newest 10-10 list... I downloaded the zip file and unzipped it just fine. When I clicked on Process and pointed to the file, it started processing, but never got past 5000... it just seemed to be in a loop and did not finish. Then I could not stop and exit the processing without terminating LOGic.
It seems I cannot upload the png file at the moment...after I click on UPLOAD, it says no file chosen.
WN4AZY on 8/20/2026(UTC)
#2 Posted : Friday, August 21, 2026 12:26:46 PM(UTC)
Sorry, I could not reproduce that here. No problems here.
Let me sleep on it.
Try watching the task manager before and after it hangs.
#3 Posted : Saturday, August 22, 2026 4:47:07 PM(UTC)
Let me sleep on it.
I'll try it again... if it doesn't work, how about we talk about it next week and you can log in to see what's happening... I'll let you know what happens...
#4 Posted : Saturday, August 22, 2026 5:28:53 PM(UTC)
OK, this time I restarted my computer and redownloaded 10-10.zip. After unzipping it, I tried 3 times. The 3rd time it took, but it never stopped. I finally had to use the task manager to end it after it got to 180,000 records, which I know is not possible, there aren't that many 10-10 members.
We'll just have to get together next week.
Screenshot 2026-08-22 172438.png (21kb) downloaded 26 time(s).
#5 Posted : Monday, August 24, 2026 4:15:24 PM(UTC)
Strange. Mine stops at 85000. That IS correct, even though the largest 1010# is 79000-something. They pad out the end of the file with dummy records where they put the future 1010 number in place of the call.
I wonder if our 1010 files are different? Please open 1010.txt in notepad. Turn on View/Word Wrap. Scroll to the end of the file. What do you see?
#6 Posted : Monday, August 24, 2026 4:16:51 PM(UTC)
here is the end of my 1010.txt:
K4KPD W4SV WB3EFPKD9YXSW6PNQ N1HEX KQ4RHJNG9J K9IVN N5ZCW KK7PQXKQ4KGPKC3UHVKC8BPFK7IAL KO4GQSKD5LPJK1BJC N5DJY KA5PXEN6RAM KE2BFRVA6VA K4MW WA2WOVVA7RLSKI5WIZK4SGK W4BZM KQ4NXEAI5BE AI0H KC1TLFKG7SXFW4SDX NT9A 7/M0TJK4HI W5JWP KB8UUEKE9BDAAD6DB KD4UTLVE7KEGKF0OVLKE8VGNK7ZDP N5WGA W7WX KK7YPCKQ4SMTF5PKR K7NNT K4ZMA NK2MC KO6GSUKC7E K0CLW VE7IADWB0NYDW4FXZ W2DON K0XM K6FRJ AJ6UU VA3UMMKF0HXIKJ5IFLW6PS KK7PQQK0LWO KF8BDTAE5AU KF6JS WB9JNZK5VS K3GGR KB9STBK7NEB N5GP KQ4PCRKK7VJVK7MEE W0HC N7AW KI5OVGW7KMJ W7GEZ KI5EWGDC1RW DN9WOAKF5YRJDK2TN I1GXV K5GAW KF7YII78435 78436 78437 78438 78439 78440 78441 78442 78443 78444 78445 78446 78447 78448 78449 78450 78451 78452 78453 78454 78455 78456 78457 78458 78459 78460 78461 78462 78463 78464 78465 78466 78467 78468 78469 78470 78471 78472 78473 78474 78475 78476 78477 78478 78479 78480 78481 78482 78483 78484 78485 78486 78487 78488 78489 78490 78491 78492 78493 78494 78495 78496 78497 78498 78499 78500 78501 78502 78503 78504 78505 78506 78507 78508 78509 78510 78511 78512 78513 78514 78515 78516
84757 84758 84759 84760 84761 84762 84763 84764 84765 84766 84767 84768 84769 84770 84771 84772 84773 84774 84775 84776 84777 84778 84779 84780 84781 84782 84783 84784 84785 84786 84787 84788 84789 84790 84791 84792 84793 84794 84795 84796 84797 84798 84799 84800 84801 84802 84803 84804 84805 84806 84807 84808 84809 84810 84811 84812 84813 84814 84815 84816 84817 84818 84819 84820 84821 84822 84823 84824 84825 84826 84827 84828 84829 84830 84831 84832 84833 84834 84835 84836 84837 84838 84839 84840 84841 84842 84843 84844 84845 84846 84847 84848 84849 84850 84851 84852 84853 84854 84855 84856 84857 84858 84859 84860 84861 84862 84863 84864 84865 84866 84867 84868 84869 84870 84871 84872 84873 84874 84875 84876 84877 84878 84879 84880 84881 84882 84883 84884 84885 84886 84887 84888 84889 84890 84891 84892 84893 84894 84895 84896 84897 84898 84899 84900 84901 84902 84903 84904 84905 84906 84907 84908 84909 84910 84911 84912 84913 84914 84915 84916 84917 84918 84919 84920 84921 84922 84923 84924 84925 84926 84927 84928 84929 84930 84931 84932 84933 84934 84935 84936 84937 84938 84939 84940 84941 84942 84943 84944 84945 84946 84947 84948 84949 84950 84951 84952 84953 84954 84955 84956 84957 84958 84959 84960 84961 84962 84963 84964 84965 84966 84967 84968 84969 84970 84971 84972 84973 84974 84975 84976 84977 84978 84979 84980 84981 84982 84983 84984 84985 84986 84987 84988 84989 84990 84991 84992 84993 84994 84995 84996 84997 84998 84999 85000
It was too big to post, so I removed several lines from the middle. You get the idea.
Note that there are numbers inside the body of actual callsigns as well. That is not illustrated in this example.
File size is 510,000 bytes.
#7 Posted : Tuesday, August 25, 2026 2:30:15 PM(UTC)
Yeah, I'm seeing the same thing when I open the file in Notepad. What time would be good for me to call and show you?
#8 Posted : Wednesday, August 26, 2026 9:06:16 AM(UTC)
I'll be around most of the day today.
Is the file size correct?
I am not seeing anything in the code that could fail. It just sequentially reads 6 bytes at a time until End-Of-File.
#9 Posted : Tuesday, September 15, 2026 11:11:55 AM(UTC)
I think I found the problem and fixed it. Update coming out this weekend at the latest. Thanks for your help.
#10 Posted : Tuesday, September 15, 2026 8:45:20 PM(UTC)
OK looking forward to trying it again.
#11 Posted : Thursday, September 17, 2026 8:23:57 PM(UTC)
The new 10.0.36 update is there. Let me know!
LU1BJW
#12 Posted : Tuesday, October 27, 2026 11:39:11 AM(UTC)
Was thanked: 9 time(s) in 8 post(s)
Hello
Yesterday I exported the updated 1010.txt database from the Ten-Ten Member Lookup program.
Then I manually imported it into Logic 10 version 10.0.36 via Tools/Setup/Membership Lists.
I’ve done this several times in the past.
The problem is that the 1010 numbers that appear in the
“Memberships” window do not match the ones I already have recorded in the logger's QSOs
or the ones listed in the Member Lookup application.
According to the 1010 website, the only way to download the member database is through the Ten-Ten Member Lookup program.
Any suggestions?
73
Horacio LU1BJW
73
Horacio - LU1BJW
#13 Posted : Tuesday, October 27, 2026 2:01:27 PM(UTC)
Can you give us some specific examples? I haven not tried to d/l the 10-10 database since the last time Dennis updated things.
LU1BJW
#14 Posted : Tuesday, October 27, 2026 2:46:18 PM(UTC)
Hi Al,
Attached a screenshot
Horacio - L1BJW
screenshot logic 10.png (203kb) downloaded 7 time(s).
73
Horacio - LU1BJW
WN4AZY on 10/28/2026(UTC)
#15 Posted : Wednesday, October 28, 2026 3:24:23 PM(UTC)
Thanks for the info. My mistake. I fixed it here, but the server is still problematic. I cannot log onto it. Working on building a new server, but will probably put the new .37 update on Amazon s3.
LU1BJW on 10/29/2026(UTC)
This page was generated in 0.119 seconds.
