Worked Before Checkbox never displays a check
#1 Posted : 28 days ago
Was thanked: 194 time(s) in 173 post(s)
Noticed the other day the worked before checkbox in the Logform is blank regardless of having multiple QSO's showing in the Other QSO's window, basically its "dead". No clue how long this been occuring.
Running latest 10.0.29.
#2 Posted : 28 days ago
Was thanked: 61 time(s) in 56 post(s)
Same here.
#3 Posted : 23 days ago
Was thanked: 503 time(s) in 417 post(s)
It works only when Adding a QSO to alert you to open the Other QSOs window if it isn't already visible. This is all explained when you hover the mouse over the checkbox. Add a new QSO, enter a call, and exit the call field (pres {Tab}).
Making it "live" was impractical in the early days of LOGic because it took too long to query all other QSOs when paging thru your log. Even now, I suspect there could be a noticeable delay. I could hide the checkbox when not Adding, but it is a handy way to get to the Other QSOs window.
#4 Posted : 23 days ago
Ok, so duh, I did read the hover text but for some reason didnt comprehend it. I always have the Other QSO window open so, a second duh....why worry about the checkbox when you can see the Other QSO's...
73, Brad K8ZM BigGrin
WN4AZY on 2/5/2025(UTC)
