LOGic Forum
LOGic Support
All Other
Another INSTANCE of LOGic for regularly visiting friend
Posts: 180  Location: Daytona Beach, Florida Thanks: 48 times Was thanked: 67 time(s) in 62 post(s)
A friend of mine (N2WB) is currently antenna-less and will be visiting to operate. I did not want to put his log inside mine by just changing the OPERATOR field. (Too easy for one of us to forget!) I've tried playing with the INSTANCE option on a second desktop shortcut and am looking for a reference to all available options.
I've noticed the Cleanup command only seems to work on the default instance.
The ZAP program missed the Log_Pictures but does Log_Bio.
I looked for a Youtube video on this (Dennis?) with no luck. A forum search was only partly helpful.
Thanks & 73s, Don W2ZI
Hi-- Do you have the second database set up OK and is that working OK aside from the INSTANCE feature? Unless you want to both be running LOGic at the same time, there is no need to use INSTANCE. Get the second database working first. http://hosenose.com/Foru...ate-a-new-database.aspx
Let me know what is and isn't working with the second database. Tnx & 73, Dennis WN4AZY
Dennis, I've have things partially setup as below. The program and default data are in "C:\Program Files\LOGic\".
Step 1 - BACKUP! <grin>
I created "C:\Program Files\LOGic\N2WB\" for my friend's log.
I copied my ".\logdata" and ".\reports" folders into that sub directory. - I've personalized many of the reports with my call so he'll need to go back to the original reports folder contents.
I created a second desktop shortcut as ff: "C:\Program Files\LOGic\LOGic.exe" Instance=N2WB DATA='C:\Program Files\LOGic\N2WB\logdata' REPORT='C:\Program Files\LOGic\N2WB\report'
Then I ran the ZAP utlity and made sure it did not kill my (W2ZI) default data. The utility did not Zap the log pictures database or folder. I manually deleted the contents of '.\Log_Pictures' and did a Pack and Reindex from the menu.
I tried to use the 'Clean up LOGic's indexes and temporary files' from the Start menu but this only works on the default data. I ran the instance and killed it it with Task Manager. On restart it did not detect this and just started up. Perhaps a lock file that is shared?????
Next thing is the Safety log. This is set in PDA.INI. The test calls I put in the second instance were appended to the same safety log, albeit with different operator call sign.
There are several files in the main folder like form.ini and keyer9.ini that would be better split into a sub directory that could be duplicated for the other instance. In the keyer9.ini file, a [Settings.instance] section? Likewise for the other INI and CONFIG files?
I don't think the '.\data' folder needs a separate copy.
Are there other command line options I missed?
Thanks and 73s. Stay safe. Don W2ZI
LOGic Forum
LOGic Support
All Other
