LOGIC 9 DX Summitt SPOT LOG
KC6AWX
#1 Posted : Sunday, March 18, 2012 1:17:09 PM(UTC)
It seems that in LOgic9 the spot log does not upload properly using DX Summit and DXcape. Spots will go into the spot log when you first sign in but after that while monitoring they do not download proerly to the Spot Log
If you move your mouse then all will appear. It seems they are getting stuck somewhere between the download and the Spot Window
If you force download it seems to work OK
DXcape on the other hand works sometimes but then does the same thing
If you open and shut the DXcape window then it will work again for awhile
Logic8 works with both clusters fine
Anyone else have this problem
It seems the telnets work fine
#2 Posted : Monday, March 19, 2012 6:09:58 AM(UTC)
Was thanked: 522 time(s) in 436 post(s)
This has been fixed in the latest update I posted just now.
AB6QM
#3 Posted : Monday, March 19, 2012 4:39:42 PM(UTC)
Still having this problem with the "Spot Log" not updating when using DXSummit and DXScape ... although not consistent. Usually, by just moving the mouse on the screen will update the "Spot Log". When that doesn't work, checking and then unchecking the "Display Lock" box on the "Spot Log" screen or "Force Download" will update the "Spot Log".
KC6AWX
#4 Posted : Tuesday, March 20, 2012 9:07:41 AM(UTC)
Same here
#5 Posted : Thursday, March 22, 2012 9:14:20 PM(UTC)
Ok, I let it run all night and it was still updating in the morning. The spot log window was NOT active. Will try it again.
Tnx for letting me know.
KC6AWX
#6 Posted : Thursday, April 12, 2012 11:34:22 AM(UTC)
Any work on a fix for this problem? It is really annoying when the spots do not update correctly
from DX Summit and DX cape?
AB6QM
#7 Posted : Thursday, April 12, 2012 8:35:17 PM(UTC)
I've had this problem from the beginning when using LOGIC9 and asked if there could be a fix via repeated emails and a phone call. I have been using LOGIC8 because it is working properly and my new Logic9 has been of no use to me.
#8 Posted : Sunday, April 15, 2012 9:18:58 PM(UTC)
Working on it -- your patience is appreciated.
#9 Posted : Monday, April 16, 2012 12:54:57 PM(UTC)
AB6QM on 4/16/2012(UTC)
AB6QM
#10 Posted : Monday, April 16, 2012 7:03:59 PM(UTC)
DXSummit is working great with the "Spot Log". Many thanks.
