QRZ.COM Lookups return Error
K1ESE
#1 Posted : Monday, August 14, 2017 12:04:29 PM(UTC)
Automatic look ups to the QRZ.COM callbook when I enter a callsign into the log and hit TAB result it the error with the header "Message from web page" and the text "Out of memory at line 1".
in SETUP I have QRZ.COM as the first database and it is comprehensive.
This is repeatable.
John K1ESE
#2 Posted : Monday, August 14, 2017 4:45:13 PM(UTC)
Was thanked: 522 time(s) in 436 post(s)
It's working here at the moment. The error is apparently coming from them. Pse try again. Make sure you are logged in.
BTW, I wouldn't set COMPREHENSIVE on. That will stop it from looking further if a call is not found. It is possible that perhaps a new US call is added that the FCC would have that QRZ wouldn't. Or that HamQTH or Hamcall would have a DX call that QRZ wouldn't.
Comprehensive would be only for things like the FCC. Even ULAR, which is updated daily, may not be as up-to-date as the FCC site.
K1ESE on 8/14/2017(UTC)
K1ESE
#3 Posted : Monday, August 14, 2017 6:21:50 PM(UTC)
Error no longer there. Like you said, QRZ problem.
John K1ESE
This page was generated in 0.133 seconds.
