LOGic Forum
LOGic Updates
LOGic enhancements
Recovery from sleep mode isn't graceful
Posts: 214 Location: OR
When a PC running Logic recovers from sleep, Logic first presents an error message: "OLE IDispatch exception code 0" If you hit "ignore," everything seems OK except that it takes awhile for the Telnet process to restart. This is the only program I use that shows an error after sleep. Can this be fixed?
Bob, N7IP
Do you think Telnet is causing the error? Try disabling it and letting it sleep and see if the problem goes away. The reason I ask is the the guts of Telnet are going to be replaced with .Net stuff.
Yes Dennis, with Telnet disabled no error msg pops up when the PC comes back to life. When do you expect to replace the telnet code?
Bob
LOGic Forum
LOGic Updates
LOGic enhancements
