Recovery from sleep mode isn't graceful
N7IP
#1 Posted : Thursday, July 28, 2016 2:51:19 PM(UTC)
When a PC running Logic recovers from sleep, Logic first presents an error message: "OLE IDispatch exception code 0" If you hit "ignore," everything seems OK except that it takes awhile for the Telnet process to restart. This is the only program I use that shows an error after sleep. Can this be fixed?
Bob, N7IP
#2 Posted : Monday, August 1, 2016 2:34:38 PM(UTC)
Do you think Telnet is causing the error? Try disabling it and letting it sleep and see if the problem goes away. The reason I ask is the the guts of Telnet are going to be replaced with .Net stuff.
N7IP
#3 Posted : Wednesday, August 3, 2016 11:29:55 AM(UTC)
Yes Dennis, with Telnet disabled no error msg pops up when the PC comes back to life. When do you expect to replace the telnet code?
Bob
