12Mhz not showing in band column
KA1J
#1 Posted : Thursday, October 8, 2015 8:52:59 PM(UTC)
It's curious but I'm seeing spots for 12Mhz, it's just that the identifier of 12M is missing in the band column on the spot log. I see 40M, 17M, 15M 80M & so on in the appropriate segments of spots in the band columns but 12M does not appear.
For instance; right now in the spot log I see TX3X and it has the value listed for instance of of FK-C, Frequency; 24.8900, mode; Phone but in the band column it is blank. Under Tools > setup > bands 12M is listed under the frequencies. Not sure where this niggling omission is coming from.
Idears?
Thanks & 73,
Gary
KA1J
#2 Posted : Friday, October 9, 2015 5:55:18 PM(UTC)
Hi Gary--
Good to hear from you.
24.89 is technically not a valid operating frequency, as it is a band edge. If you want LOGic to spot 24.89, go to the band table and change 24.891 to 24.890.
