A Script Error has occured...
#1 Posted : Monday, December 12, 2011 8:33:19 AM(UTC)
This error is generated by Internet Explorer, which LOGic uses to gather DX Spotting data (DX Summit for example) or callbook info from the web.
These errors are caused by problems with the associated web page (typically advertisments), so it is not something we can fix. The workaround is to turn off script error reporting.
Exit LOGic. Run Internet Explorer. Click Tools/Internet Options. You may have to press {Alt} to get the menu bar to show.
In the ADVANCED tab, look for Browsing. Under Browsing, UNCHECKMARK "Display a notification about every script error." CHECKMARK "Disable script debugging (Internet Explorer)" and "Disable Script Debugging (other)"
Then close all browser instances. Now run LOGic.
#2 Posted : Tuesday, December 13, 2011 7:35:22 PM(UTC)
Well, it turns out that I followed my own advice and still get errors occasionally from DX Summit. Clicking NO to the dialog that asks "Continue running scripts on this page" continues OK. Will continue to research this.
#3 Posted : Saturday, February 4, 2012 11:04:08 PM(UTC)
I told LOGic 9 to just ignore these errors. It is fixed in LOGic 9.
